- Dec 13, 2005
Howdy folks-
I just recently got myself an inexpensive french press and a cheap coffee grinder. Put it off for a long time for some reason! I've played around with it a couple of times and the quality of coffee it makes is just outstanding.
Like I said though, the grinder is cheap. No variable speed or 'coarseness' control, you just hold down the power switch till it's of a proper grind size. I only mention it in case it is the cause of a small issue: when I finish my cup o' joe, there's some black sludge at the bottom. I don't drink it and it's not a huge deal, but I'd assume its from an overly fine grind? It's hard to fix though because the majority of the grind is actually pretty coarse, it's just there is inevitably some small particles that pop up.
Anyone else notice this from their french press? Would it go away with a nicer grinder? Either way, I'm kinda hooked. Some good effin java.
