Something about the straight spine and no belly to the blade just dont do it for me but like I said I'm not the one who will be carrying it.
I agree, I was going to mention that a little belly in the blade, with the tip a bit more narrow than the heel, would be more graceful. Another thing about it that bends my eye a little is the front of the scales- IMO they generally flow better if forward a little at the top. Not sure if it's me or the pic or what but it appears that there is a glue gap or burn on one side of both pins. It may not be, but in photos of a knife for sale even the appearance of a flaw can be a deal breaker. The mark could be centered a bit better between the top of the grind and the spine. Your grind line looks a bit washed out, a real hard backing and adhesive glued, not merely held on, can help with this. I'm not personally a fan of knives featuring a plunge which leaves an unsharpened heel behind the edge. The heel will begin to stand proud of the edge with repeated sharpening. I'm not saying I've never done it, or that it's intrinsically bad.
Now for the positive: I like the overall knife, and the workmanship does look good. The wood is nice. You got a good dark maker's mark and the blade sanding looks good. The overall proportions are pleasing and the pins are placed well. The photograph, while maybe a bit dark, is clear and a good composition.
You asked for feedback. Nice knife.
ETA: finally loaded all the pics. I'd add two things about finishing. Your sanding strokes look a little muddled toward the tip on the obverse side- using a rubber or hard leather backer faced sanding block/bar with water and pressure, just dragging can help blend well. You can use this block in conjunction with a harder block for the grind line with care. And, I see that the sanded spine of your knife appears to contrast with the buffed over look of the spine in the handle. The buffed area kind of runs up into the sanded area and peters out. Either go back and sand the tang in the handle with a thin backer and masking tape, or buff the whole spine, or masking tape the spine at the front of the handle and drag sanding lines toward the tip of the spine. Then you will have a clear visual demarcation.
