If its not in the hardened spot, then you've annealed soft steel. Whats the point?
Yup. I'd be afraid of work hardening along the bend line ...The point is that even if soft, the steel can only be bent back and forth a couple times before it will still just snap off. It may break/tear off when trying to straighten it just this one time. After all, a centimeter up, the steel is quite a bit thicker than the paper thin steel at the edge, which is what this method is really for. Heat and/or annealing may help keep it from breaking off entirely.
