Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Phil,
If the phrase was "Forged and Frozen', you would be correct, but Frozen Forged" cannot be read that way. The word frozen modifies forged.
In "Heat Treat(ment)", the word HEAT correctly modifies TREATMENT, as the process uses heat to create the changes. Cryo is part of heat treatment for the same reason, as it is part of the cooling process.
Daniel,
1095 gains nothing from cryo, so I would not suspect that it is done to these blades. Maybe the catch phrase came up because the shop is below freezing all winter ( as mete suggested).
The only similar phrase I can think of is COLD FORGED, which normally refers to drop forging low carbon steel at room temperature. While this works fine for nuts and bolts, it isn't good for shaping high carbon blades.
A few smiths have tauted this as a superior method. Here is a read on one;
http://www.navaching.com/forge/coldforge.html
Daniel,
