FS- 2 High End Surefire Tactical Lights
Feedback: +42 / =0 / -0
I offer:
1. SureFire M900V-BK-WH, Vertical Foregrip Incandescent WeaponLight with IR Navigation LEDs, Throw Lever Mount & 1.62" Bezel, 125 or 225 Lumens, Black $325 Shipped
2. SureFire M600 Ultra Scout Ultra-High Output LED Weapon Light $210 Shipped
Please email paul.werfel@stonybrook.edu
Sorry Folks,
Selling this and had more stuff than I thought... Hence price change....unnamed (3).jpgunnamed 2 (1).jpgunnamed.jpg
The Vertical Foregrip LED WeaponLight - M900V from SureFire features white-light and infrared primary-illumination as well as white-light secondary/navigational illumination. The vertical grip delivers significant gains in weapon-control during sustained-fire and tactical maneuvering.
Twisting the self-locking selector ring on the M900V's dual-spectrum V-series head selects the WeaponLight's primary illumination mode. The operator can choose from a hard-hitting 150 lumen screaming tunnel of blinding white-light, or a 120 mW IR illuminator beam for use with a night vision device. In either mode, the M900V's TIR lens produces a tight beam that is well suited for CQB and medium-range targeting applications.
The M900V is fitted with very efficient recoil-resistant LEDs that are virtually immune to failure - they have no filament that can burn out or break. The WeaponLight's housing is constructed from a combination of Nitrolon polymer and Mil-Spec anodized machined-aluminum to ensure battle-worthy reliability. The entire system is o-ring and gasket-sealed for optimum weather-resistance.
To control the primary illumination system, the M900V is configured with two tactical switches that provide momentary/constant on operation. Additionally, the M900V also has a rotary switch that provides constant-on operation with a lock-out/deactivate option. The M900V also features low-output white-light navigation LEDs that can be activated by a momentary-on pressure-pad thumb-switch.
Secure and reliable mounting of the M900V is handled by its integral quick-release throw-lever mount. The M93 mount is compatible with most Picatinny or Weaver systems. The self-adjusting clamp accommodates off-spec rails, and it's configured with a recoil-resistant lever-lock that keeps the mount tight.
Performance Highlights
1.37" bezel
Coated and tempered window
Battery: 3 lithium CR123A - 9.0V
IR output: 120 mW, 9.0 hr run-time
White-light output: 150 lumens, 2.5 hr run-time
TIR lens: optimizes tight beam for short/medium-range applications
All LED illumination: white-light, infrared, white-light navigation
Mounting system: integral quick-release throw-lever Picatinny rail mount
Construction: Mil-Spec anodized aluminum and impact-resistant polymer. O-ring sealed for all-weather performance
Vertical foregrip: provides ergonomic advantage and increased fire-control at all times, including sustained-fire scenarios
Switches: primary beam - two momentary-on grip pressure-pad switches, constant-on/system-disable rotary switch. Infrared beam: momentary-on thumb-activated pressure-pad switch
Compatibility: rifles, carbines, or submachine guns with a Picatinny or Weaver rail mounted on the underside of the forend. $375 shipped
2. SureFire M600 Ultra Scout Ultra-High Output LED Weapon Light with extras.
M600U-A
Compact and extremely powerful, the M600 Ultra Scout Light® uses a virtually failure-proof LED to produce 500 lumens of output, and it continues producing blinding tactical light for 1.5 hours on a set of batteries. This brilliant output is focused by a Total Internal Reflection (TIR) lens into a far-reaching beam with an intense 13,000-candela central area that also provides significant peripheral illumination, making it ideal for close- to longer-range applications.
LU60A
The LU60A is an incandescent lamp module for the SureFire Scout Light®. It is interchangeable with this WeaponLight's KX2C LED head, allowing the Scout Light, when also outfitted with a SureFire FM63 infrared filter, to be used in stealth operations involving night vision devices (NVDs). Since white light LEDs produce negligible infrared radiation, they cannot be combined with an IR filter for use with NVDs.
FM63
The FM63 is an infrared (IR) filter for flashlights and WeaponLights with a 1.47" diameter bezel. Cancels out the non-infrared portion of the light spectrum to produce a smooth beam of infrared light for use with night vision devices and infrared-capable video cameras. For military or law enforcement infrared applications, SureFire also recommends the M1 Illuminator, as its dedicated infrared design may be more appropriate for mission critical tasking. Applying thumb pressure to the locking tab releases the cover; a spring mechanism keeps the open cover out of the way by holding it flat against the flashlight. A cam-locking lever keeps the entire unit securely attached to the flashlight. $450 Shipped
