FS: ALG Defense - Advanced Combat Trigger (ACT) **SOLD**
boobar
Feedback: +192 / =0 / -0
I have up for sale an ALG Defense Advanced Combat Trigger (ACT). The trigger was installed in my Aero Precision M4E1 rifle but I decided to go with a drop in self contained trigger unit. The trigger is in perfect working condition and shows only minimal signs of wear. I ran around 250 rounds through the gun with this installed and it functioned flawlessly. In my opinion this is a nice upgrade over a stock mil-spec trigger for not a lot of money.
Information from ALG's website:
  • The ALG Defense ACT trigger pull is smoother and sharper than a stock trigger. This is accomplished by polishing the sear surfaces smooth and HardLubing the trigger components.
  • Sear geometry has not been changed from the standard profile so the high reliability that the stock trigger is known for is unchanged.
  • Trigger and hammer are made from true 8620 alloy steel military specification castings, correctly carburized, quenched and tempered for high surface hardness.
  • Disconnector is 1070 High Carbon steel properly Austempered into the spring range of hardness.
  • Springs are corrosion resistant and meet military specifications.
  • A full force hammer spring is used for positive ignition of all type of ammunition.
  • Trigger and hammer pins are improved over stock mild steel by using 4140 Chrome-Moly steel that has been quenched and tempered. Pins are centerless ground to a fine finish and a diameter 0.001” larger than stock to reduce play in the trigger assembly while retaining a slip fit into the lower receiver.
  • Pull weight is above the U.S. Military minimum pull weight of 5.5lbs but does not reach near the upper limit of 9.5lbs. Generally, the pull weight is about 6.0lbs.
Asking **SOLD**
PAYPAL ONLY
for payment
NO Trades
Shipping is included in the asking price and will be via USPS Priority Mail insured with delivery confirmation to anywhere in the US.
Email me at yuengdaddy@icloud.com or PM me.
