this is a light,fast automatic,a perfect EDC -$160 paypal dlvd.if g&s add 3%
has card and tube,taken out for pics,these are hard to find.please check pics.
Bionic Automatic
Brous Blades
The goal for the Bionic Auto was to create a small, lightweight, easy to carry and affordable side throw automatic. The hollow ground D2 blade rides on our proprietary ball bearing pivot system making the deployment quick and easy. The CNC machined handle scales are made from air craft grade 6061 Aluminum and feature a stainless steel liner inlay which provides a strong and sturdy lock up for a lifetime. The Bionic flipper can be deployed 2 ways, using the flipper tang or using the manual opening option with the groove cut out above the grind. This knife has been brutality tested for the past 6 months and has been repetitively reliable.
Specifications
Overall Length: 7"
Blade Length: 3"
Closed Length: 4"
Blade Thickness: 1/8"
Blade Material: D2
Lock: Linerlock
Handle Material: Coyote Tan Anodized Aluminum
Blade Finish: Acid Stonewash
Weight: 2.5 oz.
Made in USA
Bionic Automatic
Brous Blades
Specifications
Overall Length: 7"
Blade Length: 3"
Closed Length: 4"
Blade Material: D2
Lock: Linerlock
Weight: 2.5 oz.
Made in USA
