FS: CDM Gear MTC w/3-slot rail & BMT Mag Clamp
Ken C.
Jack of all trades, master of none.
Staff member
Super Mod
Feedback: +57 / =0 / -0
CDM Gear MTC w/3-slot Rail - Used, shows signs of wear on inside of clamp. Mounted on a Rem870.
This 2oz. clamp fits in a 1/2" of space so it is perfect for the Mossberg 590A1 and just about any other shotgun with a 25mm magazine tube and room to mount it. This mount can be positioned 2 ways, left or right, and provides a solid "lock up" around the mag tube. Each position allows for a sling to be used with the included sling mount/hand stop. Additionally there is provision for a QD push button sling swivel. Manufacturered from aircraft grade aluminum and hard coat anodized it is a superior mounting solution for those with limited space or under the gun mounting requirements. One tool for one bolt is all that is needed to attach and remove the clamp or light in seconds. Fits Mossberg 590A1 Heavy Millspec Barrel and Ithaca Shotgun Magazine Tubes. Not meant for magazine extensions without a clamp.
CDM Gear BMT magazine Clamp - Also used on same Rem870.
The BMT magazine clamp weighs only 1.5oz. and is lighter than the factory Remington stamped steel clamp that comes on the Remington 870 with an extended magazine tube. You can mount a variety of rails and sling mount systems on this clamp. It can use optional 5 slot or 3 slot rails to put the light and clamp exactly where you need it. One tool for one bolt is all that is needed to attach and remove this clamp in seconds. Includes a built in non rotational sling swivel cup for QD PB sling swivels. With illumination and targeting systems getting smaller, lighter and more compact, we're moving with the industry, law enforcement and the military to provide a superior mounting platform that provides for a stronger, less complicated attachment for your weapon.Fits 12 ga. shotguns with 1" of space on a 1" magazine tube. Fits Remington 870, 1100, 1187, Benelli M1/M2/M4/M104, Mossberg 500 7 shot, 590 (not the 590A1 or SPX models, see MTC clamp), Winchester 1300, 1200.
Asking $66 shipped for both. Paypal accepted +3.5%.
