ALL 3 packs are NEW and UNUSED!!!
ATS Tactical Gear RAID II pack with Frame Sheet Insert - Coyote Brown
$175.00 Each shipped $165.00 shipped each $155.00 each
** Both come with the frame sheet that has to be bought seperate**
The RAID II is an update of the famous Lightfighter RAID pack. While the RAID was the premier assault pack, through hard use some areas of improvement were found, and addressed with RAID II. The face of the pack has a zippered utility pocket for fast stowing of items, while maintaining the PALS webbing of the original pack. The inside face of the pack is also supplied with PALS webbing, for the attachment of any MOLLE compatible pouch. Organization can be accomplished in any way the user wishes. Instead of the lash straps from the RAID, the back panel of RAID II has four one inch ITW/Nexus Tri Glides for tying into or tying down a myriad of loads. The rear pocket can fit either hydration systems or an ATS frame sheet. Three flapped tube or wire routing ports at the 10, 12, and 1 o’clock are provided. The greatest distinction between the RAID and RAID II packs is the shoulder straps. Through the input of Infantrymen, it was found that the thick straps of the RAID were hard to use when the pack was carried over armor. The ½ inch foam straps have been narrowed, and the attachment point strengthened. Load lifters are provided to improved load carriage. Additionally, there is approximately three inches of vertical travel for the adjustable sternum strap. The pack measures 1512 cubic inches. The Coyote Brown and Ranger Green RAID II packs are constructed of 1000 denier DuPont Cordura. The Multicam and ACU (UCP) version is made from 500D DuPont Cordura. All ATS Tactical Gear is covered by a lifetime warranty.
**SOLD**5.11 RUSH 72 Pack - Flat Dark Earth
$135.00 shipped**SOLD**
23 H x 15 W x 8 D
Water-resistant 1050-denier nylon
Flexible main storage compartments
Internal dividers
Compression straps
Hydration pocket
Fleece lined eyewear pocket
Sternum straps
Molle-compatible webbing on front and sides
Elastic keeper for strap ends
Name tape and flag holder
Built-in hip pads
Adjustable waistband
YKK® zippers
23 H x 15 W x 8 D
Internal dividers
Compression straps
Hydration pocket
Sternum straps
Built-in hip pads
YKK® zippers
