There are a number of great 8 inch knives done by Busse....I like their FSH variants which have just that bit more "user" features like this one...
The serrated clip works well on use with a ferro rod for fires...the idea of the serrations by the handle on the SAR4 and SAR8 can have you hitting your knuckles on the ground when striking the rod...whereas using a clip point means you can hold the knife at an angle and keep the ferro rod closer to the tinder material...which for me helps but you can get round the issue by placing tinder on a raised log or stone.
A lot gets said about a clip point damaging a "baton" but for me I see no harm in putting a few "dinks" in a baton...the weight of the variants though tends to be heavier than the standard FSH as they usually are done with .27 thick stock as opposed to .25 thick.
The handling of the variant I have is as nice as the .25 straight FSH which I also like a great deal....
The only issue I have with these knives is that they tend to be rounded slightly on the spine...not fully rounded like the NMSFNO but enough smoothing to prevent a good strike...so you tend to use the front end of the finger choil on the blade, just behind the edge, where you can get a good strike...but again like the SAR8 checkering...you benefit from raising the tinder to keep the ferro rod closer...otherwise your hand can strike the ground. You can flatten down the spine though if you want...I did this on a SFNO LE and it works excellently...a D/C finish though would be damaged doing this and it works best on Satin models....or combat models stripped and altered first before bead blasting.
The serrated clip works well though on chopping knives of this size if you want to butcher deer or similar sized animals without damaging the main blade when chopping through the sternum or the spine or for that matter when taking the head off at the atlas joint. The leg bones on deer are very hard...personally I prefer to snap the first joint back on itself rather than chop through these but again the clip does a great job here and no rolling of the blade edge can happen which has occured from at least one previous post.
I have'nt seen a NMSFNO done with a serrated clip but I would certainly think they were a great option to a FSH or alternatively if you have the skills you could do your own clip and serrate it.
