FSOT: Ultimate Man Cave Item!
Feedback: +15 / =0 / -0
X-pole Xpert model
This is the last bastion of my bachelor life. My roommate and I had this in our living room. I'm now married and have no need for it. This thing is awesome for parties! Spins or locks out. Girls are drawn to this thing like moths to a flame! Below are the specs, This retails for $329, will take $225 shipped in US. I have all the carrying cases, parts, etc. This requires no permanent alterations...can be set up anywhere, and I have personally seen a 450lb person spin on it and it didn't budge (don't ask, lol). Packs down very small and extremely portable! Please use gift option or add 3%.
This is the X-Pert model
-Below taken from their website-
The #1 Professional Grade Exercise/Dance Pole on the market!! There´s no other pole that is both stationary & spinning, bottom-loading that features the revolutionary X-Joint! With the X-Pert´s unique adjuster system, you can expand and fully lock the pole in position without ever leaving the ground! The X-Pert contains all the parts needed for ceiling heights of 7ft 4in to 9ft. It is offered in both 50mm (2in) and 45mm (1.75in) diameter and in the Chrome and Titanium Gold finish.
Micro Base Plate - smaller base for minimum contact and still maximum support
Main Pole A (bottom pole) with attached height adjuster rod and adjuster cover -Metal (not plastic) Adjuster Cover simply threads into place creating a totally smooth pole from top to bottom. With no sharp edges or threads to scrape arms or legs, you can utilize the entire pole with confidence
Main Pole B (top pole) - Only the Main Pole A and Main Pole B are needed for ceiling heights of 7ft 4in - 7ft 9in
125mm (5in) extension - Attach this extension for ceiling heights 7ft 9in - 8ft 2in
250mm (10in) extension - Attach this extension for ceiling heights of 8ft 2in -- 8ft 7in
Combine both the 125mm with the 250mm for ceiling heights of 8ft 6in -- 9ft
1x 180mm (7in) X-Joint - Comes attached to the125mm extension and used with the smallest extensions that are closest to the ceiling
2x 200mm (8in) X-Joints - Used to connect all larger pole pieces
Top Adapter - Attaches to the upper most pole piece/extension
Upper Support Dome - 16in wide dome that is able to grip a large surface area of the ceiling for extra stability and support
Hex Key - The ONLY tool you will need to properly set up your X-Pert!!
2x Carry Cases - One case is used for the pole pieces/extensions and the second for the micro base plate and upper support dome.
Photo Instructions
Shipping will run $40 or so, so I'd ask that be considered in trade or paid by receiver ...just don't want to pay a ton out of pocket...
