FT: Pentagon X3 Xenon Light **TRADED**
Feedback: +26 / =0 / -0
NIB - Pentagon X3 Xenon Light. Military Spec Type III Hard Anodized Body. Produces 135 Lumens of white light. Proprietary reflector designed for focusing the light generated into a smooth intensified light beam. 1" diamond knurl area of the aluminum body is suitable for standard gun-mounts. Measures 7" x 1 1/4". Uses three CR123A lithium batteries with 10-year shelf life (included). 60 minutes of run-time. X3 Xenon Light produces 135 lumens, sufficient to light up your surroundings, turning darkness into daylight. Whether you are part of a SWAT team entering a crack house or a mountain climber adverturing in moonless night, X3 in our opinion has the best lumen-to-maneuverability ratio. The supersized 1.5" head is fitted with our proprietary textured reflector designed for tightly focusing the light generated into a smooth intensified light beam. The light beam is pre-focused at the factory for maximal center intensity in achieving the greatest distance. The lamp assembly is completely isolated from the rest of the light while the batteries are compartmentalized to provide X3 with excellent protection against weapon recoil. The "flaming heat-sink" design of the head ensures adequate heat dissipation for thermal management of the xenon bulb in lengthening its bulb life and optimizing its performance. X3 is crafted out of aerospace grade aluminum tube using precision CNC machine in anti-reflective, anti-corrosive, and anti-abrasive military Spec Type III hard anodized exterior finish in our dual-tone design. All connections are sealed with double O-rings for extra protection against water leakage. The head is interchangeable for alternate light sources with optional conversion heads. X3 is preconfigured with TC2 push on/off PentagonLight™ signature tail-cap switch. The recessed button prevents accidental switch on. It can also allow the light to stand vertically. The anti-roll pentagonal shape tail cap makes it easy for one-hand operation. Optional tail-caps are available for additional switching functions, including momentary tactical tail-cap switch, and swivel belt-clip tail-cap switch. Three PentagonLight™ CR-123A lithium batteries with 10-year shelf-life are included.
