FT - Reindeer Antler Scandi
Feedback: +0 / =0 / -0
Blade
The blade is a custom, hand made blade by the Danish smith Per Glerup. The blade is made out of Sandvik steel 12c27 with a really good edge. On the back of the blade there is a great looking file work as a high end detail. The blade has a mirror polished surface and is of traditional stick tang type.
Handle
The main material of the handle is reindeer antler, but there is also two small pieces of curl birch. At the end of the handle there is a mosaic pin of brass and steel.
Both sides of the handle are engraved with a square pattern on top and a line on the bottom. I have sanded the handle to grid 2000 and buffed it for a high gloss.
The handle is made to be slender and easy to use, with a little curve at the end, for that really good control.
Sheath
The sheath is made in the same traditional way as the rest of the knife. The materials used are hand picked reindeer antler, leather made out of reindeer skin.
I have made a similar engraving, as on the handle, along the side of the antler part of the sheath. When the knife is inserted in the sheath the patterns seam to transfer from the sheath underneath the leather and up to the knife handle.
The three holes, on the front side of the sheath are there for two reasons:
One is for decoration, since when the knife is inserted in the sheath, you can see the mirror polished blade through the holes. The second reason is vent any moisture out of the sheath and protecting the blade.
I have made the hanger out of 3 mm leather cord with a decorative little piece of antler, with an engraving as well.
As with the handle the sheath is polished and buffed for really high gloss.
The knife has been stored in a padded case and not been used.
I'm looking for:
Customs
Gene Ingram
Charles May
J. Neilson
Greg Lightfoot
Kirby Lambert
Krein
Production
Busse
Chris Reeve
But others considerd, Im in the UK so international shipping may apply.
