Hi Butch,
I start with 2 stainless bolsters, rectangles with a flat inside contact surface, leaving extra bolster on the height and length. Transfer the 1/8" holes from the knife to one of the bolsters. Transfer holes to the other bolster. Pin the bolsters together with temporary pins [I use brass]. Grind to finish the blade and handle end. Disassemble bolsters.
I use 1/8" pins, so I use a #2 taper pin reamer and ream the outside of the bolster until I am halfway into the bolster. DEBUR the inside of the bolsters. I cut, measure and slightly champher the pins to 3/16" over length.
Drill a hole into a piece of 1/16" sheet metal and put over a hard surface. Assemble the bolsters with the pins and check for gaps.
Put the assembled knife and both pins installed over the sheet metal with one of the pins in the hole. The other end of the same pin should stick up out of the bolster. Hit Hit Hit.....
Flip over onto hard surface with no sheet metal, hit and check for gaps using a light. (Squeeze with a vice to get bolsters flat if needed.)
Than hit until pin is flat. Do the same for the secound pin.
Finish Grind.
Some people like to squeeze the pins in with a vice but I like the hammer.
I don't use the glue to fill any gaps.
I hope I helped.
Here is one with the mosiac pins.
http://www.bladeforums.com/forums/showthread.php?t=436967
