Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
We reimagined the Behemoth as something closer to a out-of-range comp chopper (this would not be legal at a sanctioned event). We thickened the stock but narrowed the primary grind angle resulting in a tall narrow grind with a lot of ass behind it. This has the same shallow S grind that's winning a lot of races.
I didn't take this super thin or crazy hard but it is tuned to CUT, not bash.
Today's sale is limited to these two, but we will start an open order sale in two weeks. This will not be a standard pattern.
Specs:
Delta 3V, 60.5 HRC, .275" thick at ricasso
Total length 17.875"
Blade length 12.1"
Weight 28.4 oz
Edge angle 20 DPS
.040" BTE
Center of Gravity about 2" out into the blade
Center of Percussion about 6" out into the blade
Despite its size it's not unwieldly.
I'll post more pictures and information later today but I wanted to go ahead and get this up early. This opens at 5:00 eastern time.
$680 in regular canvas micarta (natural or black) without shipping or sheath.
$950 with swedge, acid wash, and antique micarta (as shown)
Optional add on:
Sheath (kydex Mashed Cat) $85
Swedge $100
Acid wash $60
Satin grind after tumble (clean 220 grit finish) $150
Scales, substitute for basic micarta:
Black Linen micarta $10
OD green micarta $15
Burlap micarta $25
Rag micarta $25
Terotuf (grey or bright green) $25
Ebonite hard rubber $25
Edge cut antique Micarta $110
Rubber inlay $150
Shipping is $15. Multiples do not accrue additional shipping.
Be aware the basic configuration is a good value and a high performance knife and some of these add-ons are pretty expensive and don't really add a lot of value. For example acid wash won't make it cut better and does show wear. Satin hand grind will show sheath marks worse than the standard tumble finish. I charge a lot for the swedge because I'm the only one in the shop who does them and I'm stretched thin. I'm including these options because people want them but I recommend the standard configuration for your best bang for the buck. Except the rubber scales. You might should get those if you plan to use this, they're awesome.
Please be aware that some options are only available in limited quantities.
Today's sale is for two knives in any configuration you want.
We will have an open sale here in two weeks that I will leave open for a while. They will ship as we can build them. Blades and scales are already made so it's not really a pre-order, it's just an order.
Eric has one of these now so you can place a custom sheath order with Mashed Cat if you desire.
Specs:
Blade length 12.1"
Weight 28.4 oz
Edge angle 20 DPS
.040" BTE
Optional add on:
Swedge $100
Acid wash $60
Burlap micarta $25
Rag micarta $25
Rubber inlay $150
