- Oct 9, 2008
I decided to try G/flex after years of using acraglas based upon comments and recommendations on this and other forums. I did a couple of test pieces to make certain I was mixing and applying correctly and they seemed fine. It is indeed flexible. However, I glued up a handle last night and today the epoxy seems hard but there is a tacky film on the surface. The residual I had in a small cup shows the same characteristics; a hard, solid mass with a tacky surface. I threw away the test pieces so I don't have them to check but I do not recall that tacky surface. This has me baffled since it does seems hard and strong. In fact, I worked a small lump loose from the ironwood handle and it came away with a bit of wood attached. However, the sticky surface reminds me of a knife years ago where the epoxy did not cure. It was sticky but also soft, unlike this situation. Has anyone had any similar experiences with this stuff?
Randy
Randy
