Gah! My vacuum pump fragged itself
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
It literally ended up in shards of broken metal, it threw a rod and beat itself to death. This was a nice multi stage four cylinder 30 CFM pump I used for all of my vacuum fixturing. I've run it pretty regularly for years and today it started sounding funny. First it was "Tat Tat Tat", then with a few clunks in there and before the end of the program I was running it made a loud bang, a hum then tripped off as it seized. I was, of course, in the bathroom when it really hit the fan. Literally. Chunks of metal hit a cooling fan.
So tomorrow morning I'll be going down into Charlotte to get something else in a hurry, otherwise I'm dead in the water.
Do you guys think a multi stage rotary vane oil pump would hold up better than a positive displacement piston pump? I have a big air/water separator in line but I worry about coolant finding its way into the oil. I had thought a piston pump would tolerate that better but now I'm not so sure.
integrated circuit manufactures use rotary vane pumps that reach insane levels of vacuum and hold it for many hours. I would think that one would work for you.
I use a two-stage rotary vane pump for composite fabrication. It's a cheap, china-made, pump, and I'm always uneasy to leave it running on it's own. That being said, it has been running for the last two years with monthly use of 12-24hs straight.
One problem those pumps have is that they are not built with a good oil separator. If you don't need a lot of volume, it's ok. But if you do (either because of leakage, or because you're controlling pressure through bleeding) it emits a fine mist of oil covering everything around.
Alejandro.
