BogdanS
- Jan 11, 2015
Hello dear brothers,
With God's good will today i present you a new folder fresh from our shop - 'Galaxy' liner lock folder.
After a lot of work and investment we now have all means to create knives on the highest standards. The new 'brand' under which all our knives will be sold is called 'Microlab' for the sole reason that this is indeed where they come from. In order to cut costs with space and use the money into precision equipment we went for a cubicle small shop with a separate dust room that allow us for a lab like environment to work in
In the 'dust room' we have the 'angry beavers' as i call the bandsaw and the grinder while 'the lab' offers a dust and dirt free environment for clean and precise work.
Autocad designed blades are transposed on the ground flat steel stock and cut into shape using an industrial grade metal bandsaw that together with always fresh bands assure minimal steel structure distortion on the cut. All grinding is performed on an 'in house' designed and manufactured grinder with micro adjusted and digitally controlled angles using Austrian made Sola equipment and a perfect flat ceramic glass platen for the best results.
The HT is performed in a laboratory calibrated kiln with lab precision thermocouple and electronic control following strictly manufacturers HT diagrams from renowned EU steel manufacturers like Sandvik and Uddeholm. Tempering is done in an oven controlled through high end Digitron temperature control equipment. After the HT the blades are tumble finished in order to smoothen all sharp edges.
Handle materials are always of top quality, industrially high density micarta, high end carbon fiber composites and the list goes on; the scales are then contoured on the mill and finally hand finished for a nice fit and finish. All guiding holes are drilled on a precision mini mill to assure a perfect perpendicular hole. They are after that reamed to final quotes for very tight tolerances. Taking all these into account we use no glue into applying the scales to the tang but on request marine grade epoxy can be used. The screws all all tightened to optimal manufacturer recommendation torque (at 0.75 nm) using homologated Wiha torque screwdrivers, for best results while the pivot pin is hand tuned for optimum action.
The knives comes super sharp right out of the box and ready for use for the best user experience.
The blade is centered and has a nice smooth but firm action due to the phosphorous bronze machined washers. We make the washers on a cnc precision lathe as the micro grooved surface left behind has the overall surface wider while the contact surface is kept to a minimum, the tang rotating only on groove peaks.
All parts but the screws and washers are handmade in our shop for a one of a kind product.
The specs are as follows:
- 26c3 high carbon steel 0.93" thick - clay hardened with a nice hamon (65 HRC)
- full flat grind
- acid etch finish
- phosphorous bronze washers cnc machined
- custom turned blued steel thumbstud
- lightweight heat treated stainless steel liners
- overall length 6.5" with a blade length of 2.65"
- custom 'Meteorite' G10 and some fabulous stabilized mammoth ivory reassembling the milky way on one side and the universe depth on the other
- CNC precision made 'goblin green' anodized aluminum washers, stainless steel back screws and titanium pivot screws & brass pivots
The knife comes with a custom made A grade vegetable tanned calf leather pouch in black with 'nature' details and handmade case as in the pics.
The price for this knife is 310 usd.
All and only the best, God bless,
Bogdan
- full flat grind
- acid etch finish
Bogdan
