Pardon me if this was already posted somewhere, but would you please clarify what constitutes a “fail” in your cutting tests and what your sharpening method/equipment procedure is? Or direct me to the right thread?
Thank you!
Rope = 10mm Twisted Sisal ( Should be same as Cedric Ada ) with a pine board ..
Regular edge = 22 degree guided knife sharpener edge .. Cleaned up with 800 grit oxide ( De burr )
Wet Stone grinder 200mm - Factory ( wears a 220 grit wheel ) Edge is usually between 18 and 20 degrees unless I specifically try for 22 degrees .
To the wet stone grinder I have added a 200mm 60 grit ( bench grinder ) wheel !
Seeing how well some knives responded to the 60 grit wheel ..... I purchased a 80 grit 250mm Wheel . ( Bench grinder wheel )
Guided knife sharpeners = 3 ....
I have some 3 guided knife sharpeners now ..
Leather strops = 4 ..
Fail = Fails to slice printer paper ..
So I cut rope till the knife fails to cut / slice the printer paper ..
I go for a hard fail , knife actually / physically fails ... I dont want to make it about opinion , it either slices the paper or not !
Plan is to talk about sharpening at a latter date ..
Why knives respond diferently and the possible cause ..
I have a few more knives for 80 grit testing ..
But Utube is full of sharpening advice by experts , I'm not an expert !
One day , I would perhaps like to put my edge against others ( head to head so to speak ) .... Could be interesting to see how far behind I am .........
