I'm sorta scared about making my own because im scared im gonna blow myself up... what are the risks involved with making your own?
P.S. thanks for the advice for the Uncle Al's upright, never heard of them before. any idea on where i could get one from? I cant seem to find it on google (my googlefu is bad today.).
http://www.woodsmonkey.com/index.ph...mini-forge&catid=41:how-to-articles&Itemid=63
http://zoellerforge.com/simplegasforge.html
You can easily build one for under$100, I've done it check out these links zoeller has a bunch of designs and parts. Search forge and mini forge here , there are many options.
wait a min, there are no speical nozzles or connections you need to make a forge which can get up to welding temps? I though there was some kinda speicalized connections and/or fittings so that the forge wont fall apart or explode but it seems you just need to aim the tip of a propane/mapp torch into the hole. I though you needed some kinda blower which wont melt hooked up to the forge. is this not so? could you use a compressor to blow air in to the forge?
P.S. thanks for the info/links! I'm learning a lot.
The connectors on the outside of the forge aren't exposed to high heat. Use brass or steel. People have used hair driers as blowers, not the best but can be made to work. The North Carolina (NC) forges aren't great for knife making since they tend to generate hot spots. As a side note Fluidsteel, is your burner port centered at a 90 degree angle? or is it set at an angle? I can't quite tell from the photo.
Wayne Suhrbier
eccvets
No info on your profile as to your location. If you are anywhere near North GA, come to the Trackrock Hammer-in Sept 23.24.25 (see posting on Ga Guild Forum at KNF). You can inspect and discuss several style homemade forges, see them operate, learn pros/cons, etc. It will help you make your choices easier.
As mentioned above, they are very simple to build less expensive than you think and you learn a lot about what makes them tick and how to make repairs when you need to, if you build your own. The science has been done just follow the rules.
If you are worried about explosions.....that can happen with any of them. It won't be the forge but the operator!
For what it's worth, i built the simple gas forge on the zoeller site. I use mine for heat treating 01 and while I don't forge, i would think there would be no problem achieving welding temps with this setup. I can easily idle at 1500 degrees on very little gas pressure, usually around 4 psi .
