Why not a simple solid fuel hand warmer?
Because a flame will heat all the air under the poncho. You already have gloves.
I posted some years back that I like to have Fireworks in a kit for signaling; I must be the only one.![]()
Great piece of advice from Tobii3; and the same applies for a solo warm up with one poncho and a survival candle. If you squat or have a stool of some sorts, (stump), get the poncho bottom to the ground and that candle will warm you up and get quite a bit of moisture out of your clothes. If there were a top 10 list of short term survival tips this would be one near my top...
Getting lost while hiking is foolish but depending on circumstances I guess anything is possible. Fews years ago a hiker in California got lost and fired a flare....turns out when you light the forest and a bunch of homes on fire your going to get found!
A map $12 and a compass $25 or a flare gun???
............. A signal of any kind would be used to be found, only when rescue is flying by.
Two Army ponchos and five bungee cords. Four for the corners and one to pull the hood up to keep from sagging and collecting water.
For warmth? A storm candle. Put the other poncho on, place the hood on, then tighten the neck are as close as possible. Light candle under the poncho. Obviously, keep the candle between your body and the poncho so neither get burned. Tuck loose ends of poncho under you (sitting Indian style). Reason you keep your head out and the poncho tight around your neck is to avoid asphyxiation.
Voila. Survival in it's lightest form. Yes, I have done this, and it works.
If it's sunny it willneeman--The sound of a whistle will carry many miles
On the ground....
A flashing mirror will travel to the horizon
