Mistwalker
- Dec 22, 2007
I got a new piece of gear some time back that has stayed in my truck, and has gone out with me on all of my trips to the field since. It is a modular emergency survival system called a Gear Pods Wilderness from GearPods.com , with each component specialized to a specific need or set of needs. The wilderness kit contains a fire and cooking component, a first aide kit, and a shelter system.
It came with a canvas carry case that has quick release clips at each end for quick access to either end of the system. It will attach to a pack via a heavy canvas strap with a heavy duty snap fastener.
This system does come with a small cutting tool, more on that later, but the carry case also has a pouch on the side for adding a larger, more substantial tool, and they sell the Ritter RSK MK5 on their site. I happen to already have one. The Becker BK-13 Remora will also fit as will larger folder like a Wenger Ranger.
Each of the components is marked with a universal symbol for the contents within, and the case is set up to be market with matching symbols for easy identification of contents, a handy thing if multiple kits are involved.
The nodular system consists of multiple polycarbonate containers and polypropylene terminators and connectors. The containers open at either end and can be connected in various configurations to suit personal needs. The contents all come in their own stuff sacks so the contents can be removed and the containers used for transporting other things like water if needs be.
There are also empty containers and terminators available in three lengths; small-1.5”, medium- 3”, large-4.5”, and extra large-6”. All container are 3.25” outside diameter of terminators with an inside diameter of 2.75”. They can even be stored in two pieces in the nylon sleeve so you have more lids available and more options.
Each component comes with a list of contents, and I keep the first aid kit on the end for quick access. The FAK is a simple one but fairly comprehensive. However it also has room for adding some user specific items. For example I am going to add some acetaminophen and benadryl to mine.
While it does come with matches, a Spark-Lite, and a fresnel lens. The system marked fire component is a more complex than just fire.
The Spark-Lit and tinder-quick work really, and even works well in damp conditions, and can be used effectively with just one hand.
NATO matches and strikers individually sealed in a plastic pack
Signal mirror
Signal mirror
