Let'er Buck
Basic Member
- May 13, 2022
Excellent photography on these.Generally not a sheepfoot fan as they are not pointed enough to dig under my nails however the main on this run is small enough to do the job. The pull is a little weak for my tastes, especially on a pinchable blade ... why else have that hump sticking out unless you want to pinch it open. I don't drink beer or soda so the caplifter is almost useless except for the screwdriver. Wouldn't pry too hard with it or you'll risk loosening the blades. The spring on the main is the same size as the caplifters, giving the caplifters a perceived stronger pull due to less leverage (shorter). On the TC the spring is narrower, making the secondary on the TC an even weaker pull. It's a small blade so not all bad. If I give the main a 2.5 pull, TC secondary is a 2. TC has sweet color sawcut covers, not an acrylic fan but the orange crush looks good in the sun, but surprisingly I like the Beer Cub linen micarta covers the best. Mine has the best snap of the three on the main, decent texture in hand and micarta wears forever. Would like to score a blue / purple bone but heard they will be scarce. Maybe a stag but not a delrin fan. If you have a use for a bottle opener, ok, personally would prefer two blades. These would be killer with a WT blade configuration imo.
