So what would you pick if you could only have one?
Between those two, I would pick the Viper, because I dislike the blade grind on the Freemont. I agree with others that quality is the same, as both are GEC made. And Im a big fan of stag, so either of the two is a great choice in that regard.
Gec model 47 Viper, Specifications 3 3/4" Closed. Swayback handle, Wharncliffe blade, flat grind.
Northwoods model 27 Freemont, Specifications 3.75" Closed. Sleeveboard handle Sheepfoot blade, saber grind
The Fremont and the Viper side-by-side for comparison:
I prefer both!
Helps a Lot! And I agree Both is a best answer. Your photo shows the two knives, though specs say the same handle length, are not the same size. It would also help if you could post the weight of each knife, as that helps determine size differences.
However, I would choose neither, as I am currently not exceeding 3.5" handle sizes. Im a big fan of the 3 3/8" #15 pattern.
A single blade #15 with wood covers, weighs 57 grams in a Barlow bolster, and 49 grams in a short bolster.
Im also a big fan of ebony, and long pulls, and since ease of opening is an issue with the Viper, here is an alternative to that issue, for half the price, also with a single blade and straight cutting edge like the two you are considering (the #15 does not have an overly firm pull even if you use the nail nick):
http://gunstockjacksknivesandcollec...53113eo-stl-huckleberry-boys-knife-ebony-wood
Here is a Barlow I strogly recommend, that is in stock
http://gunstockjacksknivesandcollec...ow-sfo-single-spey-blade-in-african-blackwood
fwiw, bone adds 8 grams over wood, and barlow bolsters add 8 grams over short bolsters. In hand, I actually prefer the balance of the Barlow bolster, over the short bolster which makes the knife seem more blade heavy, unless you go with bone handle, or a capped head like this:
http://gunstockjacksknivesandcollec...oute-152114ec-single-spear-blade-ebony-wood-d
yes, take a moment to digest your choices. Beware the slippery slope, many of us cant buy just one knife
