Gen 2 Titanium Shirogorov Tool Bits!
REK Knives
Moderator
Feedback: +51 / =0 / -0
I am pleased to announce our new Gen 2 Shiro bits! I had these bits made in Taiwan from Grade 5 (6AL4V, knifemaker grade) Titanium and are made to precise tolerances to fit OEM Shirogorov screws. They are designed in such a way that they will not mar the screw heads whatsoever.
All of these bits are now made to fit the standard 1/4" nut driver screwdriver, which we will also be offering in the near future. They feature quick connect indentations which allow the bit to be locked in place with the proper screwdriver. With the exception of the proto bit, they also are tapped in the end for a 6-32 screw which make refinishing a breeze and will allow you to install a set screw if you want these to work with magnetic drivers!
Note that these are individual hex tool bits, so you will likely need 1 for the pivot and 1 for the body. The proto bits are slightly different than the gen 2 production bits (longer head, larger quick connect indentation, and no tapped hole) so we are selling these at the regular price of the steel bits.
Head measurements are:
  • Pivot Tool Bit for 111 (ex lg) - .091" thick x .341" wide
  • Pivot Tool Bit for most models (reg, e.g. 95, Hati, F3, etc.) - .076" thick x .315" wide
  • Body Tool Bit for most models (reg, e.g. 95, Hati, F3, etc.) - .062" thick x .218" wide
  • Body Tool Bit for Neon, Neon Zero and HatiOn (micro) - .049" thick x .139" wide
Bumping this, just upgraded the micro bit to fit the Neon Zero for those interested
