- May 4, 2005
Has anybody used this?
Opinions?
I can get a pretty good deal on it.
75-850 - MILLING / DRILLING MACHINE
Head swivels 360 degrees.
Zero setting dials.
12 speeds from 90 to 2020.
Adjustable gibs on table.
Adjustable stops on table.
Heavy-duty tapered roller bearing spindle.
Standard accessories: 1/2" chuck, 1/2" chuck arbor, 3" cutter, 3" cutter arbor, angle vise.
SPECIFICATIONS MODEL 75-850
Drilling Capacity
1 1/4" (32 mm)
Tapping Capacity
3/4" (19 mm)
Face Mill Capacity
3" (76 mm)
End Mill Capacity
3/4" (19 mm)
Swing
15 7/8" (405 mm)
Max. Distance Spindle Nose to Table
18" (480 mm)
Spindle Taper
M.T. 3 R-8 NT30
Spindle Stroke
5" (130 mm)
Diameter of Spindle Sleeve
3" (75 mm)
Spindle Speed
60Hz, 110-2580
Forward and Backward Table Travel
7" (175 mm)
Right and Left Table Travel
19 3/4" (500 mm)
Work Area Table
28 3/4" x 8 1/4" (730 x 210 mm)
Motor
2 HP, 220 V, 1 Ph, 9 A
Weight
594 lbs (270 kg)
Opinions?
Zero setting dials.
Drilling Capacity
1 1/4" (32 mm)
Tapping Capacity
3/4" (19 mm)
Face Mill Capacity
3" (76 mm)
End Mill Capacity
3/4" (19 mm)
Swing
15 7/8" (405 mm)
18" (480 mm)
Spindle Taper
M.T. 3 R-8 NT30
Spindle Stroke
5" (130 mm)
3" (75 mm)
Spindle Speed
60Hz, 110-2580
7" (175 mm)
19 3/4" (500 mm)
Work Area Table
Motor
Weight
594 lbs (270 kg)
