Geometry and proper sharpening vs steel quality
I assume that your material is concrete reinforcing rod (rebar) stock. This comes in several grades based on yield strength rather than chemical composition. The middle grades are commonly used in serious construction projects. This is likely to have .4% to .5% carbon content. It is likely that you are working with something close to hot-rolled 1050 alloy steel. This is basically crude machete stock.
There are a couple interesting things that you could do with this material. You could experiment with hammer cold forging of the edge. This is what was done in days of yore to harden an edge. You could also experiment with heat treating the blade to get it up to the low 50's in hardness. Try heating your blade past the Curie point and water quenching it. Then draw it in a 375 F oven for an hour or so. If you were real ambitious you might try hot forging it to a thinner profile before you heat treat it. A propane torch could probably provide you with enough heat for these experiments.
Thom,
Good point. It's unlikely you'd be able to improve on a custom maker's work, but with practice, you might get good results modifying a high quality production knife. It probably wouldn't be worth the effort modifying a cheapie production model though, except for the practice.
Cliff,
Regarding your reply to Thom. The maker might not have optimized the geometry for the tasks that you might deem most significant, but in that case, whether he's highly skilled or not would be irrelevent. Buying a knife designed for the uses you had in mind would probably make more sense than having to modify the edge geometry.
Geometry defines the limits of cutting performance, steel defines the limits of functional geomtry.
Very well stated. The steel itself may not play a direct role in how well a knife will perform, but "better" or more well suited steel would allow greater optimization of the edge geometry, and thus better performance. The experiments with 52100 Ed and his colleagues have done over the last few years is probably the main reason he's been able to modify his edge geometry to get such thin edges on his blades without weakening them.
-Jose
Originally posted by Cliff Stamp
regarding a maker's skill with a certain steel:
This isn't an absolute. Their idea of high performance might be massively different than yours, see the recent Fowler thread for a rather striking example of such a difference of opinion. A maker also has to be experienced in the type of cutting to know how to make a blade to do that well. I would not count on high grade steel implying anything about geometry optomization.
I wasn't saying that high-grade steel made or guaranteed a high-grade knife. My comment to Mr. Reyes was supposed to mean that I expect a person who knows his or her chosen alloy inside and out to make a better knife than someone who just cranks out a knife with a 'steel is steel' or 'better steel makes a better knife' attitude. The difference between Ed Caffrey making a knife out of 1084 and me making a knife would be a beyond night-and-day difference. Were my knives to be representative of 1084, that steel would get a worse rap than 420J2. Especially since I don't make knives...
Mr. Stamp also said:
There is also a tremendous amount of hype in the industry about the effect of steel quality (base composition, manufacturing and heat treatement) on the performance of a knife which skews the geometry aspect to the far side.<snip/>
Go back to 1998 and check the lists and usenet and see just how much performance was pushed purely on the basis of steel quality, geometry was almost ignored, especially edges which were rarely if ever mentioned.<also_snip/>
Well, I'm glad that I wasn't into discussing sharp, pointy things back when others held the superstitions I still hold. So what you're saying is that the primary factors would be geometry and the hardness and toughness imbued by the heat-treatment and that steel type is secondary because an indestructable, barely dullable steel is worthless as a knife if it's not shaped, sharpened, and hardened and tempered appropriately for what it will be used to cut. Would that be a correct interpretation?
Mr. Stamp stated:
I started off wondering just how badly a mild steel knife would fail to function as I had seen makers saying it wasn't even a useful point to practive on so I assumed one of two cuts into wood and it was dead blunt. I intended to work up trying a few alloys setting some usable limits. However it turned out that the simple mild steel knife was easily capable of handing tasks which are often used to promote the higher end knives.
Sounds like even some makers believe some of the myths, then. Since most of their market is made up of collectors, users, abusers, and odd steel-snob hybrids of collectors and abusers ("Accumulators" was Buzzbait's term), it probably wasn't an assumption that didn't seem worthwhile enough to be challenged.
Mr. Stamp concluded:
I myself used chicken bone cutting as a entry standard for toughness mainly as I assumed that it was some kind of decent standard simply as people warned against it. It turned out to be just another example of more promotion than fact. Of course any knife has to be able to handle all of the above, with absolute ease, and even then that only puts you at the level of performance of a knife ground out of mild steel - this isn't a huge standard to aspire to of course.
If I get some time this week I think I am going to try and cut a thinner one, say 1/8, but maybe more likely 3/16", and see if at that thickness it has the necessary stiffness to still enable it to whittle woods and such.
If these knives perform all of the tasks that wonder-steeled knives do, will you be selling any of these Rebar-acudas to the general public?
Very interesting. I just started down the road or trying to make knives. So please forgive any lack of knowledge on my part. I started by making several blades out of mild steel since I had some around the house as a way to pratice different grinds. I will have to play around with them and see how they do. A couple of questions, it makes sense that you could get a knife made out of mild steel sharp, it also makes sense that it wouldn't hold a edge as long as a better steel that was heat treated, but what does this imply for better steels. Say D2 for example. How much better would it hold a edge then the mild steel even unheat treated? How is mild steel when it comes to impact? Not so much in the edge rolling or chipping but some kind of major cracking or shattering (don't want to "test" anything that I made and have it explode) . I have read much about hardness being related to impact toughness on some steels.
When a material fails under sudden impact it either breaks like glass or tairs like foil (or something in between). In both cases the failure tends to start at one point and then extend across the material. The failure starts at a spot that either has higher stress or where the material is locally weaker. If the material is uniform the failure tends to start where the stress is generally highest (commonly the outside surface of a material you are bending) or where the stress is concentrated (at a place where the material has a sharp corner or crack). Hard materials are vulnerable to stress in general and to stress concentrations. When you apply stress the material can't flow plastically to even out the stress in the region of highest tension. So hard materials like glass tend to break abruptly when stressed. They may resist deforming to a higher level of stress than softer levels, but they fail by breaking. In general a softer steel will have higher impact toughness.
A file will break if you drop it on a cement floor because it is very hard and has a lot of grooves in it. If you cook it in an oven for a few hours it will become softer and much tougher. You can use it to make a knife blade.
More work with the tension bar knife on wood :
The knife was used to cut down four Alders about two inches thick. On the first couple I attempted to just chop them down, this was not functional. It would take a hundred chops to get the stick weakened to the point where it could be jumped on or broken by bending / twisting. This was a massive amount of work compared to a decent sized knife or hatchet which would take this wood down in 1-2 cuts at maximum. The last two sticks were cut by bending the wood by hand and chopping into the region under the most stress. This peeled back the layers of wood readily and the last stick was cut with 25 hits, 10 were misses as it was a lot of ingrowth, plus my hand was getting tore up from the jagged end so my grip was not overly tight.
This isn't enough wood to build a shelter, about double the amount of sticks would be needed for just the top and back side, however considering how inefficient the first two sticks were cut, using the technique developed at the end, esaily eight sticks could have been cut with the knife with the same amount of chops, so the knife had the potential to cut down enough wood. The sticks were from 7-9 feet in length, and had 2-3 major branches from 0.5 to 0.75 inch thick, solid ones which could be used to frame out the sides. Many smaller branches could then be used to weave in the gaps. The sticks were fully limbed out, and even on the last stick the blade was still sharp enough to pop off the small branches, 1/16" thick.
After the chopping, the blade still had the abilitity to cut the heads off of grass stalks with a wrist pop. Later that night it was used to cut paper and tape for packaging, just a few pieces of each. It was steeled, but this made little difference, five passes per side on a fine ceramic rod and it was back to smoothly shaving sharp again.
Work with the tension bar knife on cardboard :
The cardboard was 1/8" thick, ridged, it was cut with a full slice over the three inch blade, sharpened with a fine ceramic rod to a shaving finish. The cuts were made until the blade was unable to cut the cardboard without tearing it. The knife cut six meters of cardboard before being so dulled. It was then steeled, and it could cut another meter before it would rip the cardboad again. It was again steeled and another meter of cardboard cut. The knife was then brought back to a fine shaving finish with three passes per side on a fine ceramic rod.
Jeff, I don't think it is actually hardenable, but it would be interesting to try. This was a piece off a tension bars removed from a fence that was torn down. It is very soft, the same length for example is much easier to bend than a six inch common nail. It would have been more infomative if I have started with a piece of 1020 cold rolled (or whatever), but I never really intended this to be anything more than a diversion - it didn't go at all as I expected, the knife was a lot more functional. I have a piece sent out to be hardness tested.
thombrogan :
It is a factor sure, but not the only one, and possibly not even the critical one.
What about if the other guy simply uses a more suitable steel. There is no amount of work for example that you can put into 52100 that will give it the wear resistance of even the most stock heat treatment of CPM-10V. Thus if wear resistance is critical to your knife needs you go with the CPM-10V.
Similar arguements can be made for corrosion resistance and impact toughness among others, these properties can change more than ten to one from one cutlery alloy to the next (impact toughness is about fifty to one at maximum, corrosion resistance even more, and wear resistance more than ten to one).
Does working with the knives in any way (heat treatment, steels, geometry, etc.) mean that the quality of the knives will be raised. Yes and will any R&D. The end goals are fairly critical however as are the limits of the base materials.
In regards to cutting ability just geometry matters. The use of a better steel (and heat treatment) is to allow the crafting of a more optimal geometry, one that is thinner and more acute or to enable the knife to have a wider scope of work.
Unless you have power grinding equipment or are willing to invest hours of hand grinding, the edge geometry may make or break a knife, assuming of course that cutting ability is one of your critical requirements, if it isn't then your viewpoint could obviously be very different.
Note as well that for some tasks, even the lower grade steel can take pretty much the most optimal geometry. For example Phil Wilson uses AISI-420HC for his kitchen knives (~54 HRC) and grinds them the exact same way as his CPM-S90V (~62/63 HRC) knives. The edge geometry is ~0.005" thick in both cases, with similar sharpening angles.
In this case using a better alloy doesn't allow the creation of a more optimal cutting geometry as it is pretty much minimal in both cases. The knives are fully flat ground right to the edge, zero thickness, and a very slight secondary edge bevel is applied. The "lower grade" steel also has advantages in regards to ductility and toughness (plus being a lot cheaper).
Of course the CPM-S90V version would offer better edge retention and easier sharpening due to less floppy burr formation (assuming the edge doesn't chip). However Wilson is quite to point out that he generally recommends AISI-420 HC for kitchen knives as edge retention isn't that key when sharpening is so easily available, and they respond so well to steeling.
Now for some knives, which have a much higher strength and toughness requirement, the functional geometries would be very different. L6 and ATS-34 would have very different geometries for a heavy chopper. Since L6 is so much tougher and can thus take a higher hardness, it can be much thinner, especially at the edge and still resist damage.
As an aside, some people like Jeff Clark and Joe Talmadge have described various steels taking sharper edges, I have never found this to be the case and can get razor edges or very aggressive slicing ones on D2, ATS-34, etc. . Jeff and Joe however have higher standards for sharpness than I do, and are probably much better at sharpening, Jeff in particular as he actually did it as a job. I would argue for most people, edge geometry and steel suitability are much more critical to ease of sharpening, and final edge quality.
They don't, as noted the edge retention is lower, and the reduced tensile strength limits various applications. They are probably not even functional in decently thin stock, 1/8" may bend even on heavy whittling and maybe even light baton chopping, need to try that, though it would still hold up to rope cutting, foods and such obviously.
However if there is interest I will offer a few models, the base price is $500 US - NO SHEATH. $550 with tactical black coating (marker), shipping is $50 outside of NL, expect one month for the dog team to reach the coast, at which time it is carried by seals to the mainland. 75$ for airmail (Pelicans).
Jose :
Yes, this is ideal. It assumes of course that either you or the maker know how to determine the optimal geometry or materials.
You can find the same edge geometry on knives by David Boye in *cast stainless* steel, and even in cheap production knives like an Opinel. Once bone cutting is removed from the intended scope of work of the knife, there really is no limit to the edge geometry.
I have a D2 blade ground much thinner (no secondary edge bevel, edge is ~5 degrees per side, 3/32" stock). Alvin Johnson grinds knives that make the Pronghorns look like prybars, his knives are fully hollow ground on thin stock, and the blade are ~0.010" a quarter inch back from the edge, 64-66 HRC on various carbon and HSS.
Feth :
[D2]
With a full annealing, I would not expect a lot more as the D2 would be very soft as well, and hardness is one of the main factors in edge retention as noted in the above (the response to steeling), plus I don't think the wear resistance would be great in a spheroidized steel.
... of major cracking or shattering
It is near impossible to induce fracture in low alloy steels, and very soft steels in general. They will essentially just deform until they rip apart.
-Cliff
I have seen Rebar-acudas at a knife show in Denver. They were made from around 1/2-inch rebar. The blade was forged to be wider than the original stock. The handle had the original rebar ribbed pattern. The handle was deburred and maybe tumbled to a smoother finish. It was also plated with something like brass (I forget whether the blade was also plated). This was a fairly highly evolved blacksmith's toy. It may have been intended as a letter opener.
Cliff,
A knife can be designed with very specific uses in mind. I own some kitchen knives that take a keen edge and cut very well. The steel is hardened to the extreme and the geometry is very thin. They'll never be used outside of the kitchen so it's ok that they're fragile, to the opposite extreme that makes your rebar knife unsuitable for general field work.
I understand the point you're trying to make and agree with you to a certain degree. When you have a knife that will primarily be used for a certain task, you can design it with that function in mind. However, if you can also impart it with the ability to function in other realms as well, such as bone cutting or use as a prybar, then you have a tool that will be more suitable for use in the field.
I'd like to order one of your tactical black models. What kind of delay and extra charges am I looking at to have you fit one with an ivory handle? :D
-Jose
Thanks Cliff. I don't have the money to spend on one of those beauts. My sinuses went crazy and I have to spend my money on guafensin and psuedoephedrine instead your knives or malt liquor. :(
Do you have any contact info for Alvin Johnson? His knives sound like pretty interesting.
This has been very interesting. I would not have thought this steel would have done as well as it did. Though I always knew that what Cliff is saying about how edge geometry and sharpness are just as important as the type of steel used was true, this really goes to show just how true.
Tjanks once again Cliff for sharing this testing with us.
More hemp cutting :
Over the weekend the hemp rope cutting was repeated twice including full sharpening each time. The edge during the initial run mentioned in the above, didn't look as same in regards to the style of the micro-serrations, however when it was done I assumed this was just reflecting the steel. This was mistaken, the next two runs had crisp edges which looked just like the teeth formed on quality cutlery steel (teeth up to 0.15 millimeters deep). The initial run had square tipped teeth, which after going back over my notes, is a burr.
Averaging all three runs, the blade starts off cutting the hemp taking 22 +/- 3 lbs on a two inch draw, and smoothly increases up to 40 +/- 3 lbs after 126 cuts. The variance is so large due to the problem with the first run, it was included just to set a lower bound. The knife is also bent and this can be felt on the draw which hampers performance, the latter runs were also taken with thicker edges simply due to the repeated sanding, at 14 and 14.5 degrees per side respectively. With a straight knife, with a thinner edge, another round could be possible and thus 254 cuts obtainable. 500 maybe, if the edge radically lowered, ~5 degrees per side, assuming the edge doesn't just buckle straight away at that angle.
After the rope cutting, the edge was very worn and showed little aggression. It took 5+ cm on the poly under a 1000 g load, and could not slice newsprint. Under magnification large flat regions could be seen, sections of the edge that were worn completely smooth. Some teeth were present, but vastly reduced in size, down to a third or less. The edge was also very distorted, nothing which could be seen by eye, but under magnification dents could be seen up to 0.1 millimeters to the side. After steeling the performance would increase, but only back up to ~28 lbs, not close to optimal, again indicating the effect of significant wear.
Hard plastic :
After sharpening to a high polish, 22 degree micro bevel on a fine ceramic rod (five passes per side and then five per side alternating), the tension bar knife was used to cut the top off a pop bottle, make multiple cuts down the sides and trim off the bottom section which is very thick and hard plastic. No visible damage to the edge, no reflection of light.
Metal cutting :
The knife was stabbed into a soup can lid [thin metal, 0.008" thick] and then worked across it, and repeated making a plus sign which was pried open. This didn't visibly damage the edge, but it was now reflecting light along the contact areas. The can was washed out and the knife stabbed into the side which was of similar thickness but ribbed, again worked back and forth to make a slit up to the top lid. This didn't significantly effect the blade further.
The lid of the can was formed by a double layer of much heavier metal, 0.038" thick. The knife had a *lot* of difficulty in trying to cut this metal on a push or a pull, a serious attempt was made with both methods, getting only to 3/4 of the way through. The blade was then inserted under the cut with the blade resting on the opposite side of the top of the can to serve as a leverage point, the knife was then able to cut through the lid by pressing down on the handle, though with difficulty.
The attempt to push through the lid induced a dent in the edge about 0.5 cm long and the blade was 0.015" thick at the back of the dent. The pull induced far less damage, about 0.2 to 0.3 millimeters deep, and less than a millimeters in width. The rest of the blade also suffered some impaction, as the knife slipped along it on both cuts after failing to go through the lid, the impaction was less than 0.1 millimeters in depth.
Reference :
The metal cutting was repeated by the next lowest standard on hand. A "stainless steel made in Japan" kitchen knife, 0.035" thick, with an edge grind of 9 degrees per side (personally modified), 22 degree per side micro bevel with the same fine ceramic rod.
The knife cut through the lid on the same type of can, with no visible damage. It made a cut up the side with no further problems, and was thin enough to just be pulled through, no need to be worked from side to side. Again a leverage technique was used to cut through the lid, this induced a small bend in the edge, 0.1 millimeters to the side about one millimeter long.
As a check the side cut was repeated, and an attempt made to cut through the lid on a pull, this failed, though a push succeeded. The blade however was so thin and weak that it was flexing all over the place on both attempts. The pull induced small chips about 0.1 millimeters deep, the push which was much heavier and made a chip about 0.5 millimeters deep and twice as long. The push chip was large enough to be visible by eye, the knife was 0.005" thick at the back of the chip.
The push made a larger chip mainly due to a flex in the knife which caused it to bend during the cut and thus induced a lateral snap on the edge - the knife was simply too thin and didn't have enough stiffness to remain straight. The knife was sharpened in under a minute, 1000 and 4000 grit waterstones followed by a 5x5 sharpening on a fine diamond rod which left an edge which could cleanly slice newsprint.
Due to the massive difference in blade geometries, the two trials can't be completely contrasted based on steel differences alone. The thinner blade generally went through the metal easier, however due to flexing it took much more strain when trying to cut through the can lid. In any case it is clear that the grade of steel is higher than in the tension bar knife, and further that soup cans are not a high stress test as they failed to induce damage even on a very thinly ground cheap kitchen knife when sloppy technique was used with high force. Even the tension bar knife was not seriously damaged.
A shot of the knife :
http://www.physics.mun.ca/~sstamp/images/tension_bar_knife.jpg
Jose :
Supply the ivory and I'll throw in shipping for free, next day turn around.
When you have a knife that will primarily be used for a certain task, you can design it with that function in mind. However, if you can also impart it with the ability to function in other realms as well, such as bone cutting or use as a pry bar, then you have a tool that will be more suitable for use in the field.
Yes, it comes down to how much damage are you willing to accept after doing the hardest task you can imagine, that is the durability design constraint. The more damage you will take, or the more narrow the scope of work, the greater the cutting ability that can be produced. The biggest problem from the makers point of view is dealing with the human factor, how skilled is the user and how strong. The impact energies can easily be difference by several times to one from person to person on the exact same work.
thombrogan, he posts on rec.knives, he is a hobbiest maker, I have no idea if he even takes orders. Website :
http://www.panix.com/~alvinj/
Keith :
I knew it would be usable, however I would not have predicted it had near the level of performance it did. It forced me to evaluate my current baselines for performance in several areas.
-Cliff
