- Jun 23, 2008
I had written Gerber off many years ago after they hit the big chain stores and a couple of the combo edge flavors of the month let me down. I come to BF and they get very little love here apart from the Fiskars Finland made axes.
So life goes on...
Then earlier this month I see a Big Rock Camp knife at the Indy 1500 show. I picked this knife up and was immediately infatuated with the pattern. William Harsey is the guy behind this design.
The knife itself is around 6.5 oz. Balanced right in the dip of the index finger choil on the grip. The blade is a drop point pattern. Thickness is just a hair under 3/8" on my ruler. Fairly wide for the overall length nearly 1 3/8" at the widest(not counting the thumb ramp) and the flat grind follows suit. Blade steel is 440a(meh), full visible tang construction and SoftGrip rubber handles with torx fasteners. There is five grooves on the spine leading up to the thumb ramp for an inch or so. Very comfy. Layed out spec wise looks like this.
Gerber Big Rock Camp Knife
- Full-width tang fixed blade
- Nylon logo belt sheath w/ protective insert
- Overall Length: 9.5"
- Cutting Edge 4.25"
- Weight: 6.5 oz.
- Blade: 440A stainless steel
- Handle: SoftGrip
- Blade Style: Drop point
- Flat Ground
- Straight Edge
- Bead Blast Finish
So I am stuck in the house today and what is stuck in here with me. Chores! Forget cleaning, but I got trash to take out and got some cardboard to break down too. I got four kinds, the beer box kind, regular brown, some white, and some really nasty stuff with glossy pictures printed all over it.
The factory edge came pretty even and almost arm hair shaving so I let it do its thing here. After the whole shebang I touched up the edge Sharpmaker style and it went very quickly, shaving sharp now.
Foot wise I dunno, but it filled a 15 gallon trash bag so 200 ft mabye?
Here's most of the pile from overhead. You can see my son's foot in there too, he helped daddy scatter the strips all over the floor just after this shot.
Not even a scuff on the finish, and once I got into the rhythm, the strips got cleaner and came with little effort.
The edge held up pretty good here, the wide blade and high grind were excellent for slicing, and the grip has got to be one of the most comfy I've held for as thin as it is. Here's some other cuts after the cardboard, a toilet roll I quick cut off the edge of the counter, pop bottle, and some pretty clean strips of copy paper still too.
An apple for fun, not the thinnest slices, but handles very well for the point work.
Anyway, I had all but given up on a knife in this range. Not impressed with the BRKT Bravo-1 for this type of thing although I love the A2 steel, I found the design much thicker and more clumsy throughout. Got an RC-4 waiting patiently but after today, it may be waiting a bit longer for a good workout.
Going based on my indoor testing today, the Big Rock seems a very good value for the approx $30 these are going for. Here's a fuzzy comparison shot for ya.
A couple negatives. The sheath, although not pictured, is pretty mediocre belt loop nylon with a plastic insert. I plan on making a kydex rig for it, but that too is going to take some thought, because if you were to do retention in the standard click variety, the soft rubber will get all chewed up real fast. Any suggestions here would be appreciated.
Got a good pic after honing up the knife waiting for friggin' photo bucket. Not too shabby.
Thanks for reading along and tolerating the fuzzy pics. As always, comments and questions welcome.
So life goes on...
- Weight: 6.5 oz.
- Handle: SoftGrip
- Flat Ground
- Straight Edge
- Bead Blast Finish
