Mistwalker
- Dec 22, 2007
I was a Gerber fan in my teens in the late 70s. It started with a MK-I and MK-II I carried as tools while out on my father's boat when he co-owned a salvage company and not all we encountered out on the open water were friendly. Later on in the mid 80s it was a BMF I carried when I explored the Everglades on my weekends off when I lived in Key Largo and an original LMF when I moved back to the Tennessee hills.
Recently I was looking around for a good graduation gift for a friend who just finished AIT and moving on to other training. I ran across another Gerber that interested me, it's their new LHR. It is designed by Matt Larsen, William Harsey Jr., and Chris Reeve.
The specs are (from the Gerber website)
Blade Length: 6.87"
Open Length: 12.5"
Weight: 11.2 OZ
Handle: TacHide
Full tang construction for maximum strength
TacHide handle for sure grip in wet conditions
Quick release sheath with safety release
Made in U.S.A.
It comes with a drop-leg carry system and has a quick-release safety retention mechanism as well as a retention strap with a button snap.
The knife can not be just snatched out of the sheath by someone else, the hand has to be in the position the one carrying it would use to draw the knife.
It has a really comfortable contoured handle made of something called TacHide that is also really grippy as well. It's comfortable in pretty much every grip I've used it in.
The one grip it is the least comfortable in is one used for inverted edge techniques and primarily a pulling motion. It would only be a real problem if doing an upward thrust into a solid object. Though it may look it, it isn't painful just holding the knife in a tight grip or in thrust through softer materials.
It has the same rounded, shadow-boxed tang, and glass breaker extension as other Chris Reeve knives.
It came with a really sharp edge that easily cut through multiple layers of seat belt webbing material, and easily feathered seasoned spruce.
I haven't wanted to beat it up too bad, just test it out a bit so I have so far only done some light chopping and some boring in some hard treated yellow pine with it. As I said it has a sharp edge and in chopping some small limbs at the base it cut clean through the limb and into the trunk, and light movements of the wrist was all it took to cut them in the middle. The tip showed no ill effects after multiple plunge-and-pry, and twisting motions to dig a hole through an inch of very solid, seasoned, treated yellow pine.
And it fits on a standard pistol belt without having to disassemble the belt.
I think it should make for a fitting graduation gift
Blade Length: 6.87"
Open Length: 12.5"
Weight: 11.2 OZ
Handle: TacHide
Made in U.S.A.
