That's a pretty insulting thread-title :thumbdn:
So you were throwing a plastic-handled knife at a tree and became disappointed by your poor technique? Or you were hammering on the FRN+rubber and were disappointed by your ignorance of what could happen? How does this make the Gerber a "crap machine" ? :foot:
Here is a pic from Gerber's website high-lighting the
deliberate separation of tang from pommel:
As you can see, the tang of the Gerber extends
>3/4 the length of the handle and is fixed in place by notches as well as a screw at the end. The heavy hammer/spike pommel is isolated from the tang to prevent channeling electric current should the knife be used for severing power-lines/cables, something it was designed to be able to do.
The handle itself is made from fiber-glass reinforced nylon (i.e. FRN) with a rubber overmold to insulate the user and reduce noise. The downside of this is that neither the rubber nor the FRN is as durable as solid metal or G10 or micarta and can be damaged by heavy impacts more easily than the aforementioned materials. Smashing FRN with a hammer or block of wood (or throwing) is likely to result in damage.
That said, the LMFII can endure a LOT of abuse before failure, as epitomized in Noss' destruction test of the knife many years ago, here is a link to part1 of that test, you can find the remaining parts on youtube:
https://www.youtube.com/watch?v=SKrGPjxWMiY
Regarding your cracking the FRN around the guard, that has nothing to do with the tang design at all, not sure why you brought it up
You could certainly try gluing it together if it bothers you. You can also contact Gerber's customer service department:
http://www.gerbergear.com/Meet-Gerber/Contact-Us/Customer-Service
Gerber offers a lifetime warranty against defects in workmanship and materials. Your situation is probably not covered since it sounds like you misused your knife, but they may cover you anyway, doesn't hurt to ask.
In the future, if you are going to beat on a knife, understand its probable limitations
first so you pick
the right tool for the job. Knives are tools, they are not indestructable, and a little knowledge of what they can and cannot be expected to endure will go a long way to your satisfaction.
Oh, and please don't go blaming the design or the manufacturer for your mistakes. THAT will go a long way in earning respect from others. Thank you.
