Gerber MP1-AR Weapons Multi Tool / AR-15 / M4 / M16
Feedback: +1 / =0 / -0
Suggested Retail: $159.95 Our Price: $121.95 You Save: $38.00
Free USA shipping on all orders over $99.00
http://www.knifeworks.com/gerbermp1-arweaponsmultitool.aspx#.VQrqnhvwvIU
Gerber MP1-AR Weapons Multi-Tool 30-001024
Gerber’s eFECT was the world’s first military-grade multi-tool designed specifically for the AR-15 / M4 / M16 weapon system. The MP1-AR is the next evolution; a full-size multi-tool featuring implements needed for cleaning and maintaining the weapon system, along with vital everyday tools for the field. The MP1-AR features a pin punch for take-down pins, a contoured carbon scraper for cleaning the bolt and inside the bolt carrier, and a dental style carbon pick for cleaning the bolt’s ejector area and other hard-to-reach parts of the weapon.
CLEAN WITH ACCURACY AND SPEED
The MP1-AR features a magnetic bit driver which accepts standard sized bits and is accompanied by a bit set that includes flat, Phillips, hex and Torx bits commonly needed for adjusting optics and accessories. The bit set also includes a front sight adjustment tool for iron sights and a pin punch for trigger assemblies. Also found on the tool are full-size serrated and fine edge blades, and spring loaded jaws made of forged steel, providing the ultimate in jaw strength. The MP1-AR also includes a MOLLE compatible coyote nylon sheath. Proudly built in Portland, OR.
Spring-loaded, forged steel needle nose plier jaws
Wire cutter
Wire stripper
Full-size serrated blade
Full-size fine edge blade
Takedown pin punch
Carbon scraper
Dental style carbon pick
Magnetic bit driver
12-piece bit set, includes
Torx bits
Hex bits
Philips bits
Front sight adjustment tool
Trigger assembly pin punch
