Originally posted by LongRifle
I have been trying to get my grill going for about an hour now. I think I have fire retarded charcoal, because no matter what I do I can't get the damn thing going. Matthew
Yvsa crawling fitfully up onto his soapbox.
Okay, since it's already Saturday night you're SOL this time.
Throw out the Dayumed Lighter Fluid!!!!!
You don't need it and if you don't let it all burn off the food tastes funky.:barf:
I hate Charcoal Lighter Fluid!!!!!!!!!!!!!!!!!!!!!!!:barf: :barf:
Seriously. The first chance you get try to find a local outfit that sells grills and accesories. If you don't have one locally I think they're probably available online, should be anyway and it seems I recall looking on Webers Website once and they were
there.
If it's a decent outfit they will have the Charcoal Chimneys. That's what you want!!!! (Edit. It's written below, but I found the Weber's at Home Depot!!!! Saves a trip to a specialty shop
maybe)
Personally I like the Weber's since they're quite a lot larger and one helluva lot better built than the Taiwanese chimneys, which are okay and will last about 3 years with some TLC, and they hold enough charcoal to get the job done right the first
time.
All it takes to fire one of these up is One (1) sheet of newspaper!!!!!!
At the most two (2) sheets, if that doesn't do it your charcoal is probably funky.
Sometimes I use a double sheet if I want to hurry things along a bit, probably not any faster, but makes me feel
good, Grunt, Grunt Grunt.
Crumple the sheet of newspaper and stuff it under the chimney. Fill the top of the chimney with charcoal.
Light the newspaper and in about 30 minutes give or take a little you will have coals ready to cook on. Guaranteed,!!!! (that is if your charcoal is alright)!!!!
Actually on my grill I have found that if you heap a pile of the old charcoal, if any was left from the last time, I close my grill up after cooking and almost always have charcoal left****, or put a
heap
of new charcoal under the grate where you're gonna place the chimney that it will light as well as what you've put in the chimney.
****Appeals to the conserative Okie in me.
I have used these for the last several years. I went through 2 of the cheap ones and then at Home Depot in Phoenix last April I bought a Weber's Chimney for our daughter as she was having the same trouble all the time with the lighter fluid.
I went looking for one of the others since I didn't know at the time that Webers made them and happened to see the Weber's.
They were only a couple of dollars more than the cheap ones!!!!
And if you absolutely Must use charcoal lighter there's a trick to it, learned from an ex father in law who was a fireman. Squirt the fluid on and let it set for a while so the charcoal can absorb the fluid. If you wait a little too long a fresh squirt will refresh what's already soaked into the charcoal.
If you wait just right the charcoal will start burning when a match is placed on it without the all familiar Whuumpff that we're all used to.
And by letting the fluid soak in a bit it will also guarantee that your briquets will start the first time with only one match.
The Really Truly nice thing about the chimneys is that not only does your coals start just as fast or faster than with fluid is that your meat or whatever will Never Taste like Lighter Fluid again!!!!
The other Really Truly nice thing is that you're not polluting the air and in fact are using a small amount of a product that keeps so many landfills in business.
Good for you And good for the enviroment.
More Soapbox Edit. Charcoal Lighter Fluid is also the number one cause or close to #1 cause of children getting burned badly. Macho dad squirts the lighter fluid onto a slow starting fire and when the fire comes up the stream he throws the dayumed can over his shoulder onto his kid.
This is Truly the number one reason for giving up the fluid and getting a chimney!!!!
I almost forgot when I happened to look down at my arm where I did the same thing with a Prestone Plastic Jug of Gasoline while burning heavy grass where there were still hot coals underneath I couldn't see.
That foolish act cost me a week in the hospital and a month at home and several thousand dollars and I was dayumed Lucky!!!!!!!
Off my soapbox.
And yes, That's Exactly how I feel about Charcoal Lighter Fluid!!!!
