- Apr 12, 2009
Interesting stuff so far. My King 1k didn't even darken the slurry on this thing.
The trouble is I'm getting a lot of generalities. All I'm looking for is a working edge. I like as sharp as practically possible, at the very least the edge should be a little grabby, which it isn't so far. Its getting better with the white compound I've got which should be a diamond compound. But slowly.
Now would 1 micron CBN or Diamond on leather give me a reasonably fast cutting solution, and give a reasonable edge, should I go higher, or lower? will there be an appreciable difference between CBN and Diamond at the same size? Since this is also going to be for field maintenance I'd rather go for a fast robust edge, rather than a polished perfect one. Most of my knives get done on a 800 grit ceramic, and might see a couple swipes over the green strop. Since I'm going for no micro bevel is there a reason not to use leather and just keep going flat on the main grind? Its what I've done on a mora1 and the edge is really nice. Id rather not bother with a wooden paddle strop just for durability sake.
But without knowing much about how the 3V reacts at the edge, I'm feeling like a lot of the stuff I do might not really carry over. Its not a SAK or an ESEE.
What makes you sure the 'white' compound is actually diamond? It would be very strange/rare if a diamond compound were instead just being marketed as 'white' without specifically mentioning actual diamond makeup or content. I bring this up because, there actually is a 'white diamond' product (as named/branded) out there that's got no diamond in it at all, but is instead tin oxide (made for soft metals & plastics; too soft for steel). Most of the other standard 'white' compounds will be aluminum oxide (OK for most steels, but may struggle with higher-vanadium steels in attempting to polish them highly).
I bolded the other point (about finishing on ceramic, then stropping w/green compound on leather) because, if there are relatively heavy burrs generated on the ceramic (ceramics can do that easily), the green compound on leather may have trouble removing those burrs.
If you are just looking for a 'fast robust edge' produced in 'field maintenance', and not really caring if it's polished, then the stropping issue may not be important anyway. It's likely such an edge could better be made and finished on a stone alone. For something with fairly significant vanadium content, a diamond hone would be a no-brainer choice to me, if the knife were mine and I were looking for such an edge. If you were finishing with an 800 ceramic, try using a 600 or 1200-grit diamond hone instead (F/EF DMT, for example); it'll leave the edge much cleaner (of burrs) & crisper than the ceramic likely will by itself, minimizing the need for cleaning up on a strop. That'll also very closely address the 'I like as sharp as practically possible, at the very least the edge should be a little grabby' characterization you mentioned, of what you'd like to see in your edge.
David
