Getting my CCW... What should I carry???
Hey guys!!
I am sure that everyone here knows a lot more about guns than I do :D
I am getting my CCW here within the next couple months, and I don't know what kind of gun to start out with...
Please let me know what you guys think!
Any and all suggestions will be appreciated!!!!:thumbup:
This is the first handgun my girl learned to shoot on :)
Try everything you can get your hands on. What feels good to me may be horrible for you. After shooting as many different firearms as you can base you choice off what feels good in your hand and what you feel safe and comfortable with. Choose a caliber that you trust to defend yourself with, but also something that you enjoy shooting. If you choose something that is uncomfortable for you to shoot then you will not want to shoot it often enough to stay proficient.
You have an open invitation to shoot anything I have to see if something feels right to you. The most important thing is that it works for you.
Garth
Ruger lcp or lcr, Springfield XD subcompact....... there is so many great options that you need to go to a gun store with alot of guns and get a feel for as many as you can. good luck
Garth
That is so true. Just don't let any macho men try to scare you off of something aside from pea shooter. Respect the firearm, but don't be afraid and freak out.
I suggest that you go to a reputable gun range and try several pistols. The people there will gladly assist you in testing any of the guns they have on hand. Find something that your are comfortable in shooting accurately. I've been shooting competively and have a CCW I personally carry a Glock 19. Easy to conceal accurate from the box and reasonably priced. The main thing is to find something that your are comfortable shooting as accurately as you can. Good luck.
Get a Commander or full size framed 1911 and some Busse grips :D or you could do what Garth suggested. That might work too :)
The largest caliber that you can accurately shoot and comfortably handle. As far as to what "Brand" goes, rent a few at a range and find what's best for YOU.:)
The options are endless. Like Garth said try a lot of different guns and see what you like. I am sure you know a few people that will let you shoot there guns.
Get whatever your comfortable with..
My best advice is if your GOING to carry get a Kramer Holster.
I went thru 4 different holsters which was a huge waste. My buddy said to me " stop screwing around and buy yourself a Kramer"
What calibers are you comfortable shooting, and which are you proficient when shooting? Those are two separate questions. Lots of people can shoot many calibers, but aren't necessarily proficient with all of them. Different rounds have different recoil characteristics. If you haven't done much shooting, 9mm is pretty tame while still being more than adequate. People will tell you that .22 can and has put many people in the ground. Yes, that may be true, but the round itself is less reliable in terms of going off. You can take a .22, hold it your finger tips with one hand and then twist the bullet with your other hand because of the way the round is constructed. That just means those rounds are more susceptible to moisture around you. A round that doesn't go off means you usually do tap/rack/bang. IMO, I would rather minimize another variable that could cause this, like a round where moisture got into the casing. Centerfire ammo is less susceptible to this.
As far as what to get, you have to decide on the size of the firearm (full size, compact, subcompact), the type of firearm (revolver, autoloader), the materials of the firearm (steel framed, polymer framed, aluminum framed), and the action (da/sa, dao, striker fired).
Whatever you get, almost everyone will tell you to practice, practice, practice, and then practice some more. And when you're not at the range with live fire, practice dry fire with snap caps.
Striker fired guns will be the easiest to master IMO, because they have the same, usually decent 5 pound-ish trigger pull every time. These are your Glocks, XDs, and M&Ps. Of the 3, I'd pick an XD because of the grip safety. DA/SA guns mean you have to master the double action trigger which will be heavier than the single action trigger - two separate trigger pulls.
Having said that, personally, I hate strike fired weapons because the triggers feel clicky. I prefer a mechanical feeling trigger like a da/sa/dao. I also don't think Glocks feel good in my hand, which brings me to another point. It will be to your best interest to find something that feels good and ergonomic in your hand. I also prefer steel framed over polymers. For CCW, polymer will save a lot of weight.
EDIT:
Kimber Solo Carry might be one to consider. 9mm, striker fired.
I know many of you may despise Glocks, but the G26 is my favorite handgun for carry. 124gr +P Speer Gold Dots and your gtg. :D
As others have said, find what fits you, and then practice like holy hell with it. If you're going to be effective, you should know how to control your weapon like you know how to drive a car---you just do it, you don't think about it.
You should carry the weapon you are fully trained and capable of using with precision 100% of the time.
Once you let go of that bullet its a forever decision, there is no room for error.
So whatever make, model and caliber that shakes out to be, that will be the one to carry.
This is the best advise so far. To this I'd add that you need something simple to use under stress, that doesn't require you to disengage safeties, rack a slide, etc., which leaves us with a revolver, .38 sp./.357 magnum, that is if you are comfortable with it, and can shoot it accurately (misses don't count). After you have learned a bit more then you can
"up-grade" to a pistol.
You need a small S&W revolver, like this 442. Trust in Powernoodle: you aren't going to carry a Glock 19 or a 1911. Too big. And the triggers are too light for a first-timer. You want a small pistol for easy concealment, but one with manageable recoil. With a relatively stout trigger pull which helps you prevent a negligent discharge. Try them all, but then settle on a small .38 revolver, Kahr PM9 or Kel-tec PF9. Want a gun thats no bigger than a CD case, but will still alter someone's behavior? Check out a Ruger LCP.
Smith & Wesson 442.
Ruger LCP.
My vote is for an AR15!
o, concealed? I have a kahr 9mm that I like, you should feel one up and see if you like it
IDK, seems like too much thought is going into this one? I just handed my girl (looks to be built similar and petite like you) my 45 and showed her how to hold it. Then I held my hands over hers for the first shot. Within one clip she was grouping around the bulls eye from about 10 yards. She shoots it no problem and she is by no means "strong".
You can get aluminum commanders.
I am really thinking a revolver would be a great gun for a newbie... I always get a little freaked out with automatics cause they are... well, they are automatic. ;)
