- Jul 31, 2015
High production is not what I'd be doing. Not even close.
I already have the drill press working fine. I replaced the original two prong power cable with a grounding one. Took the motor apart and cleaned it out. Wiped everything down and oiled the raw steel parts. I have not officially measured run out, but I chucked up a 16" rod and it has almost no perceptible wobble. Definitely better then my old HF press that was doing what I needed.
I have rand a lot of lathes in my day and by far I would pick a manual over s cnc for s home shop no questions asked. Yes cnc is faster but that's not counting the set up time. Even in a production/shop environment if I only had to make 1 or 2 parts it was much faster doing it on the manual. I would take a manual "clunker" in a heart beat.
Since the original motor for mine is working well, I see no need to go with a new motor. I had considered a VFD and new motor, but the stock pulley system and motor ( I believe it's 1/2 hp) seems to have the speed range to do anything i will need. Is 2 hp for a bench top drill press really necessary? I'm assuming you would go that big, just to make sharing the VFD viable.
If you're interested in restoring old, obsolete machines, you'll be in for a fun time. If you're looking for machines to use to make parts, don't waste your time even picking up those old clunkers. Certainly if you don't don't have a giant shop where they can sit over in the corner until you have nothing else to do and money to burn. Years ago when I stated out I made the mistake of thinking some old machines would be "good to have" and I ended up scrapping them all, wasting time and money. Older machines can be a good value IF they are already restored or still in top working order and those things look like neither.
