- Mar 18, 1999
I knew right out of the package that I would like this knife. It's not heavy, balanced right and feels great in hand. Fit and finish is nice. Like other Beckers I have owned, the scales don't align perfectly with the tang, but it doesn't cause any issue in hand. That's about the only gripe, and it's no big deal. Knife came razor sharp, with a perfectly even edge grind.
The sheath (probably the bane of Doug's existence by now!) is nice. I like the fact that it has the PALS strap on it, fits great on my little Gerber day pack.
I had some really nice weather to work with
Even had a little trickle of water since it actually has rained in the past few weeks
Took a few glamor shots before I started using it. It really is a great looking knife, I love the blade shape.
I did some chopping, nothing too crazy, a few branches about thumb thickness
I moved up to some thicker, denser wood and it chopped right through. Then I carved on it for a while
I went to play with the handle weights, and they were larger hex size than the handle bolts. But I only brought the one wrench (It pays to read the direction sheet, the size is stated right on there!
I did some drilling with it. I like that it has a nice sharp point for such a broad blade
But the point is also strong. I beat the tip in and pried out pieces of wood no problem.
Just an afternoons worth of use, but I really like this knife so far. It is larger than what I normally carry, but it definitely will see some use. I will post more as I use it more. Here's a parting shot, posing with his little friend
