You could get away with the usual heat to a dull red and quench. It's the method used for annealing non ferrous metals in order to erase the work hardening.
The quench is only useful to get back to work fast, the real annealing it's just cycling aroung the recrystallization temperature...no problems overshooting it unless you melt the metal
It's a case where a simple torch works, but if you need to do into a kiln, you'll save money by setting the lowest glowing temperature...in any case try to be sure it's at least not under 750 °F to be effective.
If you anneal to higher temperatures the brass will be very soft, you'll find your sweet spot for the eyelet application.
