- Mar 3, 2006
Ever checked out the Spyderco Assist?
No offense to the original post, however, we should consider that the design on rescue knives is based on the experiences of EMT's, Firemen, and Military paramedics.
From Blade HQ, the Kershaw Rescue Blur
Last thing you want to do is cut someone's arm or leg to pieces tangled up in netting, rope, etc,(rope entrapment) cutting circulation off while fighting raging flood waters.
But when we need a knife its usually for cutting... or prying
because it should...No rescue knife IMO should be limited to a single blade with only a pointed blade. If you want to carry a pointed blade knife at least make sure you still have a blunt tip somewhere on you for back-up. Last thing you want to do is cut someone's arm or leg to pieces tangled up in netting, rope, etc,(rope entrapment) cutting circulation off while fighting raging flood waters.
This is the one I have! Actually had to use it once to cut someone out of an overturned car! It worked great and I didn't stab the person.
For sure, giving the case, you can use any knife to cut a seatbelt or to free a person entangled in any kind of webbing or rope, although it's actually a fact that you are going to hurt him. In an emergency situation, no matter how experienced you are, you are not really going to have a steady hand as you struggle to free a trapped person (you have to consider most rescues are done against time, with smoke/water/dirt/fire around you) that's where a recue tool comes into play, it allows you to be precise and protect the person your are helping.
Take for instance a person with a broken ankle, you are gonna have to remove his boot in order to immobilize it, try cutting thorugh a boot with a sharp point knife without causing more damage or moving the injured area. Been there, and the best tools to do that are safety cutters. Benchmade makes very good ones, even the one by Gerber is quite good.
If you want something more versatile, try the Spyderco Rescue 79mm or the Benchmade 915 Triage.
