- Dec 21, 2006
I thought I would share this, just in case someone now, or down the road, might need the info. I recently acquired a glass kiln, top loading, with elements in the lid. It is 110V, so takes about 1 hour to reach 1500F. I had some concerns about being able to take a blade out and get into the oil quickly, and safely...with the elements on the under side of that lid. I was using a wire of sorts to hook into the tang holes and lift out and into oil, since I didn't have a long set of tongs. Even with long tongs that have an angled head......opening and holding that lid while trying to quickly pull a blade out and into the oil in the proper orientation is not fun. It is do-able for sure...just not ideal.
Then I got to thinkig of making a modification to allow easier/faster handling. There is already a peephole on the side wall of the kiln. You can take out the peep hole plug and it has zero effect on the temperature. I thought I would cut a slot from that peep hole, down to the floor level of the kiln, very thin...just thick enough to slide a 1/4" thick blade into (if I ever made one that thick). The cut was a rectangle shape, measuring about 5/16" wide by 1 5/8" tall, with the round peep hold on the top of the cut. Looks like a golf ball on top of a tee. I cut the aluminum (I think?) casing with a dremel wheel....just because I could....and then cut the firebrick with a hacksaw blade (without the frame). I've never cut the stuff before. It almost falls apart!!!!
There is no problem at all, as I figured there wouldn't be. I was just apprehensive about doing it. It is warming up nicely this very moment. I have a CruForge V blade to normalize and austenitize today. I have a piece of Kaowool over the homemade hole while it warms up, just in case. Now I can simply slide the blade in and out......lickety split. I know this doesn't really help a whole lot of people, but maybe someone can use the info down the road.
Thanks for ALL that ALL of you do here!
