- Oct 3, 2012
Like many I've been milling around the forum with the notion of making knives, just as a hobby... I've searched the threads and read up tons (thanks count!) but haven't found the answer to a couple of questions that have been plague me the last few days. Which I'll address in two 2 separate threads to avoid cross contamination.
My first question is; Is it easier (read: more beneficial) to learn good filing technique (getting the grind angles and plunge cuts etc just right) making larger or smaller blades? My plan is to make a two or three of the same thing, then go in a direction, larger or smaller, making a few of each type of blade design (maybe changing the grid) until I've reached the other end of the spectrum.
In my head, the larger the blade, the more "forgiving" things will be (more metal to move if I mess up) (as many suggested I'll be starting with full flat grinds). I know there's a few things I'm missing, like the taper on the blade, is it necessary? (distil taper if memory serves) but I'll address them as they come up.
Let me clear a few things up before assumptions are made. I don't intend on using a grinder or sander of any sort, I live in a condo and the kind of noise those makes is a big no no. Not to mention the fact that I can't leave that sort of equipment out on the balcony for any period of time (I have to setup and break down every time I intend on working on a project). If I can find a place to have a small shop where noise isn't a factor, this may change, but for the time being it's files only.
Maybe I'm just over thinking this and I just start filing lol...
Anyways the input of the experienced would be greatly appreciated.
I won't be able to respond the next few days, I'll be traveling on business but I'll definitely back!
K
EDIT:
I've noticed some differences of opinions in regards to my next question, so I'll post that after I've got this bit sorted
K
EDIT:
