- Feb 5, 2010
So often I have heard folks express the sentiment "Go thin to win." I have obviously taken the message to heart, especially after the two slicers I just made.
Only this time I may have taken it too far.
I started with CPM S30V bar stock that is 1 inch wide, 0.145 inch thick. The blade is a derivation of one of the Global knives my wife loves so much. The Global knife has a distal taper on the blade (0.09 at the plunge down to 0.02 at the tip) and an integral handle that is about 0.3 inches at the widest spot.
Mind you, I did not set out to make a clone, just something of similar size with superior sharpness. So the first thing I did was grind in a similar distal taper, then I set to doing the primary bevel grind.
Long story short, my blade is now significantly thinner than the Global it is modeled after. At the plunge it is 0.06, and it tapers down to 0.015 at the tip. At the edge it is 0.015. Worse still, I am not done with the pre-HT hand sanding. I'm not terribly concerned about most of the blade, but I am a bit concerned about the tip.
Do you think I'm likely to have a problem during HT?
