going on my first back packing trip
Dont forget your Duct tape...Wrap some around a pencil.. The first moment you feel some rubbing on your feet use duct tape..Its easier to prevent a blister then try and take care of one. I got no idea where you are going .. But as was said before make sure you are warm at night. As a first time just get mountain house food. Hot chocolate before you go to sleep makes a world of diffrence. Dont forget a map and for the first time go backpacking where the trail is easy to follow.
Lets not forget watch where you go there are bears tigers and bigfoot out there. They are hiding in the shadows waiting for you.... Take lots of pics.
Sasha
For two nights, you shouldn't need too much.
Have a water container, preferably a water bladder for the hiking part and a nalgene bottle for storage and when you make stops. Fill up your water as often as possible and don't forget to hydrate as you hike. Depending on the altitude of your backpacking trip, you could be sweating and not even know it.
Take tablets as well as something to boil water in, while trying to hike to a new location, you won't be able to take an hour pitstop everytime you run out of water to kick up a fire. Maybe once in the mornings and evenings, but while you are hiking use the tablets to keep yourself on the move.
Take a bandana for whatever you can think of.
First aid kit is a must have. Be sure to put moleskin in it if the kit doesn't already include it. It is a real life saver when it comes to blisters and things that could mess up your feet. Can't really hike with a foot out of commission.
Take a pair of liners with your socks. Meaning a thin stretchy pair of "undersocks" to put underneath your normal socks. I prefer underarmor socks beneath wool socks. Extra cushion and it prevents blisters and sore feet.
Dress appropriately. Take a rain poncho no matter what the weather man says. Get one that can cover you and your pack. Just because a pack says it's waterproof doesn't mean anything when it's put to the test and your clean clothes get all wet.
Keep snack foods with you for during your hike, and keep the bigger meals for your overnight areas. This keeps you full of nutrients as you hike without having to waste time making lunch.
Have more than one way to make a fire. Whether or not an open fire is permitted, keep your fire-making ways with you.
Be sure to have fun! Make the most of your stay and be safe. Hope this helps, J.
Someone already said Space Blanket - also suggest chamois type towel - minimum weight but even when wet you can wring it out and get near dry - just in case you fall in the water or get rained on -and chocolate - you can never have too much chocolate
I guess that after being in this W&S forum for a while you should have already figured out yourself. Pretty risky asking such a question, you may end up with answers like that from gunknifenut (pretty funny btw..).
Anyway, since you asked it and taking Boomsticks list as a base (best one so far) I will try to make it even better.
first off.. break down your gear list into sections. make a check list. let someone know when you leave and right when you get back. tell them exactly where you are going to be!
clothing.
rain gear. is always a must in my pack.
socks 2 pairs
gortex boots---> If rain/snow is not expected and you won't be doing any off trail hiking, maybe you are better off with lighter shoes. They breathe better with no membrane at all.
base layers.
primaloft jacket---> Great advice for humid/raini conditions. If you expect to be below 0ºC all the time, down is more insulating, lighter and less bulky. It is also way more expensive.
beanie (stalking cap)
gloves---> Again, if dry conditiones are expected, stick to windproof fleece gloves. They breathe well and are vey warm (in the heavier models). If you plan to use them for rough work, bring along a pair of working leather gloves and save the expensive ones for when they are really needed.
pants with cargo pockets. they become useful--> I don't like cargo pockets, they sag if you carry anything heavy or bulki in them. They catch in the bush. Indeed I don't like to carry anything in my pockets while hiking. If you wear your pants high up in the waist so they don't impede high steps, anything in your pockets will interfeere with the packs belt. I don't even carry a belt on my pants (elastic waistband). If a knife on your belt is a must, try to craft some kind of dropleg. Again, each to his own!
bandanna. to cover neck or face if it is too cold---> great piece of gear, but try to stay away from cotton.
sleeping
sleeping bag---> Sleep fully clothed but don't overstuff the bag so the insulation can do the work. If you try to get fully dressed into a small sleeping bag you will probably compress the insulation and it won't trap air at all. It happened to me once in the Alps. I was shivering in a bivy, I took off my primaloft jacket and I felt way warmer. For a two day trip, unless you drop your pack into a stream, I would suggest down.
ground cloth---> Ditch it. Bring a sleeping pad instead. Ground cloth doesn't insulate at all. RidgeRest work great, no risk of puncturing and the crests and crevases keep the moisture away from your sleeping bag.
7 strand para cord
tent stakes---> If in the bush you can withle them from a death branch (great excuse to carry a knife). If in the snow, you better bring a bunch of plastic bags to craft dead man anchors. Same goes in the sand.
TP\ trowel
safety
safety kit. (band aides and anti diaretic)
pad of paper and penicl, knife, compass,water treatment tabs, e-blanket, ductape, moleskin, map, reflective mirror, firesteel, cotton balls soaked in vaseline, spare battery for the flashlight, zip ties, mini bic lighter
lighting
flashlight, check the batteries before you go---> Redundancy is always a great option, but I would bring a second led headlamp instead.
headlamp, windproof waterproof matches, mini glow stick.--->Unless you are going to ride a bike, climb or cross pitch black glaciers, leds provide enough lumens while lasting a lot. Long ago I ditched glow sticks, they seem like a great idea but I just can't see how to use them. Sure you can attach them to your gear so you don't lose it in the dark but if you are going to be sleeping at night, you won't lose your gear.
food
if you are doing a heavy hike think of foods with a high calorie content. bring some snacks! mountain house I think makes the best trail dehydrated food. chili mac is my favorite.
bring a water filter! iodine tastes pretty bad---> Agreed. Iodine tastes pretty bad but filters are heavy and don't work "on the go". Stick to Micropur since it uses silver salts as a purifying agent. They take a bit more time than iodine to kill germs but they are tasteless. If you bring two 1l bottles (or a bottle and a bladder), drinking from one while waiting for the tablets to work in the other as you hike is no big deal. If you think Micropur is not enough, try Micropur Forte. It has iodine but it is not as bad as other brands. If you are worried about the waiting time, then get the liquid versiones. They work faster.
And this being a knife forum... here is the mandatory knife recommendation: Bring whatever makes you happy. I am sure you have plenty of blades, axes, hatchets and folding saws.
Oh! And if you are into the LEAVE NO TRACE way of life... bring a light LPG stove so you don't need to burn half a forrest to boil a cup of water to make tea.
As a side note...
sasha said:
...Dont forget your Duct tape...Wrap some around a pencil.. The first moment you feel some rubbing on your feet use duct tape..Its easier to prevent a blister then try and take care of one...
Agreed you are better off preventing blisters than taking care of them, but duct tape is not the way to go. Before anyone jumps on me, let me say I have tried it before and it didn't work. Duct tape is waterproff. Its waterproffness is indeed one of the great things about this kind of tape. The problem is that our skin needs to breathe. Duct tape impedes that. If your feet sweat (and so far I haven't met anyone whose feet don't sweat), duct tape will end up getting lose due to the moisture build up under it. You are better off using medical tape (Leukoplast, Mepore, etc) that let's your skin breathe. Don't wait for any kind of burn to show up to patch you up. Tape your heels before you start walking as well as any other spot where you feel you can get a blister (from previous hiking trips). The ouside of the big toes sometimes develop blisters.
I hope this helps, but again, if you read this forum often, you should have figured this out long ago!
Mikel
Here is a list of what I took on a 3 day trip last year around this time in the Catskills. It's a bit more than I usually take but we had temps from the 20's to the 50's. We also saw snow at night.
Adam
PS I can post food lists and my on body/clothing worn lists if you want.
Basics Eureka Mountainpass tent 77.50
Ground Cloth 1.50
Marmot Sawtooth 52.00
Mountiansmith Ghost 38.0
Mt Washinton Pad 12.00
Clothing GG Stuff Sack 2.00
LW long underwear bottoms 5.50
LW long underwear top 5.75
Marmot Precip jacket 12.00
Marmot Precip Pants 7.0
Montane windshirt 3.00
Synthetic Tee 5.00
Merino Wool Socks 3.50
Underwear 3.00
Cold Weather Balaclava 1.00
Duofold expedtion tights 10.00
Fleece Beanie Hat 1.00
Fleece Headband 0.50
OR 300 fleece mittens 2.10
Patagonia Micro Puff Pullover 12.50
Teckwick Thermo Shirt 11.00
Thorlos Trekker scoks 4.00
Cooking 16oz Nalgene Wide Mouth 3.20
BIC mni lighter 0.50
lexan spoon 0.5
MSR titan kettle 4.20
Pocket Rocket 3.0
Essentials (2) 32 oz Wide Mouth Nalgene 10.00
10 MP1 tabs 0.25
50' Chord&SilNylon stuff sack 2.75
Becker BK 11 4.00
First Aid / Survival Kit 5.00
Map & Small Compass 1.00
Pack Cover 1.50
Pack liner 1.50
Pre filter 1.50
Toilet Paper & sanitary gel 2.00
Expendables 32 oz water 32.00
food 3 day trip 57.00
Peak1 Fuel 7.00
Misc Cell Phone 4.00
Disposable Camera 3.50
PT Auroa 3.00
wipes 2.00
Total Weight 419.25 (26.2lbs)
that list is also considered a base list for me also. if you have the cash buy light titanium gear, a pack that weighs less than 2 pounds, sleeping bag 2 pounds, I use a denatured alchol stove that is less than an ounce. my pack fully loaded for 3 days with food and water is maybe 20 pounds for the winter. it is about 15 in the summer.
I dont know what you should bring, but you should climb a big mountain, dont bring a cellphone, or gps locator...you wont need water, or food. If you dont have a mountain, go deep into the desert..its cool.
If anyone in your family asks where you are going tell them Atlantic City..get really specific..give them a hotel and room number. That will fool them.
I dont think you need a first aid kit really, what could happen? If you cut your finger, you could just find some dried animal dung, and crush it, spit in it, and rap your finger in a leaf with this poultice...works everytime.
Good luck, its still a good time of the year, so you should only bring shorts and a wife beater too. Maybe boat shoes..I call them loafers.:thumbup:
Hey wise a$$ i mean like stuff people usally look over and im not going alone and will be within a 2-3 miles from my house. i will have a phone and basic first aid
In addition to the regular backpacking gear, I always find room for a couple of 'luxury' items: Camera and journal book.
Lately I've also been carrying a GPS. I don't navigate with it, but collect waypoints at various locations to see where I've been after I get back home; goal-oriented backpacking trips are less appealing now, and currently I'm more of a pack-carrying wanderer. :)
Are you going to walk in circles? Even if you only manage 10 miles per day (that's a very leisurely pace), three days and two nights should put you 30 miles away from your starting location, or 15 miles if doing a there-and-back trip.
Or you could make fifteen two-mile loops around your house. :D
I was listing like something to boil in...
#10 coffee can works well. Turn it upside down and fry on the bottom. Holds enough water for bathing/washing. Works well either on a fire or stove. It's free. And if you don't feel like cleaning it, you can throw it away when you get home.
clothing.
socks 2 pairs
gortex boots
base layers.
primaloft jacket.
gloves.
pants with cargo pockets. they become useful.
bandanna. to cover neck or face if it is too cold.
sleeping
sleeping bag,
ground cloth,
7 strand para cord
tent stakes
TP\ trowel
safety
lighting
food
bring a water filter! iodine tastes pretty bad.
Excellent list!:thumbup:
Here's the checklist I use - doesn't include everything, like proper clothing. It's basically just a "pre-flight" checklist, in no particular order, because I can't rely on the few neurons I've got left ;):D
Sleeping Bag
Tent/Pole/Stake/Footprint
Sleeping Pad
Meals
Hatchet
Gore-tex pants
Medical Kit
Bowl/Utensils/Cup
Hat
Bandana
Compass
Water Filter
Backup purification
Tinder
Trowel
Flashlight
E-blanket
Trash Bags
Coffee/Tea
Mosquito net
Insect Repellant
Sunscreen
Toilet Paper/Baby Wipes
Backup Fire
Hanging Food Bag
Candle
Gaiters
Cooking pots
Fuel
Stove
Knife
Cordage
Whistle
Sunglasses
Bob,
As a fellow resident of CT, where will you be spending the night? There aren't a whole lot of places to camp in CT.
I find that I usually greatly overpack because I am gear nut and like being able to have my stuff if I need it. However, that being said, on a typical two night trip I usually end up using very little of my gear. On my last two trips (two nighters), the only gear I actually used was:
Food
Water Bottle
Water Filter
Tent
Sleeping Bag
Knife
Light my fire Ferro Rod
Backpack (doubles as a pillow)
Its a very minimal list, but its what gets me by. Plus if your just two miles from your house, you can always hike back and get something.
Thats dry humor Bob, sorry if it missed.
Bob,
Food
Water Bottle
Water Filter
Tent
Sleeping Bag
Knife
its a place in meriden were people hike i looked on the internet if you could camp and it said as long as your not on the trail and no open fires so i will just make a fire pit.
I wrote that before i saw your second post i didnt know you were just playing around and i wouldnt ask if i knew what i needed
Your going to do fine, just go for it on this one..your not going out very far, so not having something isnt really a big deal. Bring some paper, and make notes while out there, in between having fun. Gene
