I have no complaints with the Elmax blade in my ZT801 it performs about the same as my S30v/S35VN ZTs. One thing I really like about Elmax is how amazingly sharp it gets without a lot of work.
Not the most ringing endorsement considering Kershaw and ZT S30v often tests on the low end of things (57-58hrc)
Ive read Kershaw runs elmax and S35V at 60-62.
Speaking of S30v still, if you go through actual hrc tests here, they're always 57-58, and before the site update, the KAI website had 57-59 as the listed range.
I had my 0561 tested and it was 59.5rc, and its a good steel tho I'm not blown away by it.
I had mine tested at the heat treater when I dropped off my own blades. Any heat treat shop will have a rc tester, and if they don't well then they need not be in business...That is a damn nice number for toughness. Im sure you will be happy.. 58-62 is what the steel can take. Ive hit metal a few times to zero negative effect. Im sure each batch is a bit different. Mine has been great. who can I have test it . Are there certain types of business with this machine I can look for locally?
