GONE-Sinn U2 EZM 5 on Bracelet-LNIB !
smittyc5
Platinum Member
Feedback: +314 / =0 / -0
Please only comment in posting to purchase. Direct all other comments , offers, or inquiries via email or PM.
Please contact me at conan417@yahoo.com
Sinn U2 EZM 5 on Bracelet-LNIB Super watch. Only worn infrequently. Keeps great time. Lum is incredible! Made from submarine steel.​
Watch/crystal is scratch free. Below is the watch particulars.
Gone!
Mechanical diver's watch with two time zones
• Watch diameter (mm): 44.0
• Watch height (mm): 15.5
• Lug width (mm): 22
• Lug to lug (mm): 50.5
• Weight - head only (grams): 114
• Water resistance: 2,000 meters
• Case back: Solid
• Case finish: Matte
• Case metal: Submarine steel
• Dial color: Black
• Front crystal: Sapphire
• Tegimented: Bezel only
• Inert gas: Filled
• Copper sulphate: Capsule
• Movement: Automatic mechanical
• Manufacturer's limited warranty: 3 years
• Strap or bracelet: Bracelet
• Warranty service: RGM or Sinn
Step up to the EZM 5 Professional Series with the Sinn U2. The technology and design elements used to create the Sinn U2 go far beyond standards used at most watch companies.
The Sinn U2 contains all the great features of the Sinn U1, but adds the following:
  • Second time zone complication indicated by a red tipped hour hand
  • Increased water resistance to 2,000 meters
  • Special inert gas mixture
  • Two copper sulfate absorbing capsules
  • 4.6 mm thick sapphire crystal
The Sinn U2 case is made from the same German steel that is also used in the construction of the outer hull of submarines. The steel was procured by Sinn from a steel supplier to Emden GmbH, one of Germanys North Sea shipbuilding yards who construct submarines from the very same steel.
This special steel is also amagnetic which means that is does not have magnetic properties and cannot itself become magnetized. The watch movement itself is protected from magnetic fields up to 4,800 A/m.
Because of the special steel used from the submarine steel manufacturer, the case resists the effects of exposure to salt water and salt water environments.
The uni-directional ratchet operated rotating bezel is also milled from this submarine steel which is Tegimented. The indices are machined directly into the bezel without the use of bezel inserts, which can corrode or come loose at deep depths.
The international testing lab of Germanischen Lloyd has tested the U2, and determined that the watch can be certified as water resistant to 2,000 meters. This same firm tests submarines for their ability to withstand the effects of underwater use.
The Sinn U2 has full UTC functionality through the use of an additional short red tipped hour hand which can be set independently from the primary time zone and indicates the second time zone using a 24 hour display. Screw down crown.
The U2 features an inert gas filled cavity with two copper sulphate humidity absorbing capsules, which are visible at 6.
Matte black dial with date at 3, Super Luminova on hands and markers, and striking red seconds hand complete the design.
Other features include sapphire crystal with hardened anti-reflective coating, and stainless steel bracelet.
Thanks For Looking !!!
