Gone
tpro68
Feedback: +12 / =0 / -0
I am looking to trade for one of the following, but am open to offers: Spinnaker Piccard, Undone Aquadeep (Signal or Submerge), or Deep Blue Juggernaut. Thanks for looking.
DESCRIPTION​
Casio Protrek PRW-31YT-7JF - men's watch made by Casio. It has Japanese solar quartz movement and 3490 calibre. Polymer, stainless steel case of round shape. Case dimensions are 45.2 mm. in diameter and 12.3 mm. in thickness. The dial of this Casio watch is lcd. Display type: digital. This timepiece has sapphire, antireflection coating glass. Titanium, hard coating band, band color: silver. 100 m. water resistance. The watch is from Pro Trek collection. The following features are equipped: cold resistance, radio controlled, altimeter, barometer, compass, thermometer, world time, chronograph, alarm, backlight, power reserve indicator, countdown timer, perpetual calendar, date, day, month.
  • Alarm
    The Alarm will remind you of repeated events with a beep, which you can set to any time.
  • Altimeter
    This watch can measure altitude. It is helpful in climbing, hiking and skiing.
  • Backlight
    The backlight is a dial illumination that allows you to use this watch in the dark.
  • Barometer
    This model measures atmospheric pressure. You can forecast weather changes using it.
  • Chronograph
    You can measure the amount of time between two events using this watch.
  • Cold Resistance
    This watch will work when others freeze.
  • Compass
    You will never go astray with this watch.
  • Countdown Timer
    Timer indicates the end of the time period you set.
  • Perpetual Calendar
    Will automatically show you day, date and month, including leap years until the year 2100.
  • Power Reserve Indicator
    You will always know how much energy your watch has and when it should be charged or winded.
  • Radio Controlled
    This watch receives a calibration radio signal, ensuring that the displaying time is always exact.
  • Solar Powered
    This watch can be charged from almost any light source and run few months or more in the dark when fully-charged.
  • Thermometer
    This function allows you to know the current temperature.
