I fully agree with the Spyderco Sharpmaker 204. Which by the way is NOT a gimmick. The 204 operates on a proven principle; having the same angle on both sides of the blade makes for a sharper knife. This method has been around for @100 years, originating with using the inside of a ceramic crock pot (quick geometry lesson, the circular curve on the inside of a crock pot, when combined with a flat surface of a determined length will produce the same angle where ever you place it. If you want a visual demo, get the 204 as this is described,and demonstrated in the video).
Also, if anyone here can sharpen tin snips, scissors, knives, serrations, fishhooks, chisels, forstner bits, straight razors, or any of the half dozen other things I've sharpened on a 204, with a bench stone (you have to do ALL of them on ONE stone
), I'll give you $5.
Using a 204 isn't poor care of your knives, it isn't less effective than a bench stone (which by the way, I used to sharpen all of my knives on bench stones until the first time I used a 204), it merely allows those with out the skill, or patience to use a bench stone, to achieve the same results. For my $$ the Spyderco 204 is the best value I've found in sharpeners.
Joe Glessner, owner
Sycotic Samurai Cutlery
"I can go over to your mama's house, and start a small fire in her panties." -G. Busey
