Good container for inside a MaxP bottle holder
foxyrick
British Pork
Someone mentioned in a thread about getting a round tin for a Maxpedition bottle holder. While I think I know of a few possibly well sized tins I can't get one until I can drive (or even walk) again.
So I found an alternative that we did have in stock that works rather well...
All you need to do is take a trip to the Body Shop and treat yourself or your loved one to a pot of Body Butter. I found an almost empty Sensual Ylang Ylang pot, but any flavour will do!
Once you've used up the contents, you are left with a screw-top plastic pot that's 90mm x 48mm (3-1/2 x 1-7/8 inches). It fits nicely into the MaxP 10x4 bottle holder, with just enough wiggle room that you can get it out again without a drama.
Here's the pot with a few standard measures of scale:
OK, so it's a plastic pot. That's possibly a drawback compared to a metal tin but since I haven't got hold of one yet, let's continue :D
If/when the pot makes it into actual use, I will wrap it with duct tape that will hold it together if it gets knocked hard enough to split it. It also provides a source of duct tape of course! The seam where the lid joins could be sealed if it's an emergency pot, or split with a knife if not. Then a big ranger band could be used for some water protection.
Anyway, on to some more pictures.
I've also got a nice stainless steel tin that came with some biscuits - it's perfect for fitting in the 10x4 with a Guyot inside it. I still need to put some holes in the sides and include some wire for hanging it over a fire. Even has a lid - perfect! Did I mention pictures???
The plastic pot fits nicely inside the tin, with the Guyot on top, so for me that protects it well. It could also be put on the bottom of the 10x4 of course, but would be a little more vulnerable to getting squished then.
This is the 10x4, attached to my Sabrecat, with the SS tin and plastic pot inside:
Here is the top of the stack then, it fits pretty much the same height whether the pot is inside the tin, or underneath it.
It's a perfect fit when zipped up too. The zip closes without any undue effort and the whole lot fills the pouch to the very top. Talk about made for each other!
There is another alternative that I might try out - that's putting the pot into the lid of the 10x4. It won't stay there of course, but if I glue some velcro onto the top and/or sides it will. That would make the pot very easily accessible. It's also probably safer than being at the bottom of the pouch if not inside a tin like mine.
Amazing how useful these 10x4's are!
Great idea.
I have ended up using the 12x5 because it will fit a fuel canister for my stove.
Which small tin?
The Vaseline tin has, erm, Vaseline in it!
As for the Altoids tin... see my next thread ;)
If you were looking for an actual tin, you might try those small candles they sell in metal twist lid containers?
Tins like this at sks-bottle......................................com...Just select the metal option. They have all kinds of sterile tins, both twist top and slip cover.
Have a look in Lidl's. They sell travel sweets in round metal tins that fit in my 12x5.
Geoff
Yeah, that's one of the things I was thinking of, although I didn't know that Lidl sold them. I've seen them in service stations, probably at three times the price.
I found my round tins at Big Lots on close out. They held various flavors of cheese spreads.
They fit perfectly inside the lid, and are only 1.25 thick, so plenty of room for a survival blanket between the tin and the Guyot.
(ETA: Those are 30 of the Katadyn MP1 tablets inside the bottle)
