- Dec 6, 2004
my mini mill is HF if i was doig it again i woudl look hard at the LMS one cause i ended up with most of the upgrades they offer anyhow (belt drive is soo nice)
I have better mills than HF and still prefer a drill press.Same here, I wouldn't use the mini mill from HF for drilling holes. I spent a ton of time getting rid of the runout on the mini and the way it goes down is not very smooth. I use my g0704 though.
Nathan, I know you know of what you speak, if one was looking for new, what machine would you recommend--under 1k.
An old Bridgeport or clone. And they're often less expensive than even an import full size drill press. Most of the problems I've had using drill presses in the past are moot on a knee mill. I have no idea about harbor freight and toy mills, I never understood the value of them when real industrial surplus is cheap and plentiful across much of the country. My first mill was given to me.
There is generally much less runout and deflection, so drilled holes are more round, reamed holes have less bell mouth and more consistent diameter, countersinks and counterbores have less chatter and burrs, and tool life is longer. Some mills have a fine spindle feed where you can run the tool down to the work and park it there and bump (or feed!) the work around and line a drill point up to a mark. You can switch over to collets and hold larger tools like big reamers and countersinks. You can use an edge finder to quickly locate the edges of a workpiece and feed the table over to sink a hole exactly where you want it with accuracy and no drama. A 3 phase motor can be reversed in an instant for powered tapping. They often have a backgear with more torque than a modern machining center and can drive large taps. The depth stops are truly accurate and repeatable. They have powered down feed. The ability to spot, drill and bore a hole then feed to another position and repeat means accurate layouts are straight forward (try that on a DP). In a pinch you could even mill with one. Drill presses belong in fab and carpentry shops and anywhere that needs to mix a lot of paint. If you need a minimum of floor space for poking poor holes in unimportant work a DP is fine. If it's halfway important why not just use a BP mill?
edit to add: sorry, not trying to inflame the drill press lovers here. I'm not disparaging you or your work, I'm just not understanding why not use something that does the job easier for about the same amount of money? Yes, it's more complex and heavier <--- I think that's a good thing.
Butch, you are probably right. I should use something more accurate, but have learned to make what I have work.don you really are in need of watch maker tooling with all them tiny holes![]()
if i had to split the differance ( i have both a mini mill and a "small" bridgeport ) and space was the deal along with weight the biggest dovetail "small" mill i coudl move if taken apart not sure what X# size that might be or if its the same for me and you something 2/3s the size of my bridgeport if built in the right way would be a knife makers dreamI'd Love to get the industrial stuff but some of the issues that causes us to get these benchtops:
1. No room, I can barely turn around in my little workshop as is and have no space.
2. Moving them, I don't have a truck to go and pick up any of these are the moving equipment. Most the guys that sale these seem to be far away and not interested in delivering.
3. Maintenance & parts, you have to be somewhat savvy and learn how to maintain the older machines. That is a good thing, but not for some of us who are barely hobbyist makers.
4. Power, not really a big issue but having to buy a phase converter for 3 phase vs just plugging into a wall socket is just another thing to worry about.
I think most guys shops are like mine, half of their garage, and with their wives breathing down there neck complaining about what looks like equipment hoarding already.....
Nathan, I appreciate your feedback, I will start looking for older Bridgeports or clones---can a person self teach themselves enough to use one of these, or do I need to find a class at a Technical college nearby?
I agree with all that...For drilling and sinking holes, tapping with a tapping head, etc. a good drill press with a reliable down stop is sooooo much faster and easier than fooling around with a milling machine. I can't imagine any knife shop not having one or more and I've never seen any metalworking shop that didn't.
BTW: I just checked and Clausing is still in business in the USA and evidently still making machines there, including drill presses, you guys should them out and put some money into Made In the USA!
