i just made a few friction folder and used 1095
I can suggest 1095
O1 will be more challenging to HT yourself.
I wouldn't consider O1 any harder to heat treat than 1095 and vice-versa--they both require a soak, which is difficult to accomplish unless you have the proper equipment.
If you dont have means to soak, 1084 would be the only thing I would recommend. Otherwise, pick whatever you want and outsource your HT.
Daniel, thanks for the advice.
Fortunately I have access to a surface grinder at work so that part will doable enough.
Thanks.
Mike
