- Feb 8, 2005
Hi,
Just really posting this for the sake of others who have heard of Fatwood/pitchwood, but have not had opportunity to get some in the Woods, or have wondered if it was as awesome as so many folks make it out to be.
(BTW - It is
If you have access to an area that has pine trees in it - no need for you to have to spend your hard earned $ to buy Fatwood - until you have taken a stroll through the Pines for a look.
Here's an example; Went for a walk with my dog a few weeks ago on our property and found a large Pine that had fallen over due to a storm.
Key thing was that when it fell over - many of the roots were exposed.
I chopped off a couple of the smaller roots - there was so much concentrated resin - the wood was a deep redish brown, a little sticky to the touch (though not much - as again it had been down for some time) - and beautifully aromatic. - best Fat wood score I have ever had & since it had been down for some time - it was not messy at all to clean my chopper when I got back:thumbup:.
Nutshell Version - look for fallen Pines, and keep ready eye out for any with exposed roots - as that is the most concentrated area - and the easiest to harvest. - you just chop off what you want.
To give a little idea of exactly how wonderfully flamable the savings are - it literally only takes a few sparks - and you have flame.
Also, another good indicator of whether or not you have some really good fatwood - is the "Sheen" factor.
The glossier the wood looks, combined with the darker color (the wonderful smell), and either a little or a lot of sticky residue on your harvesting tool - are all combined indicators of the quality of the score.
How do you know it is good Fatwood? - Test 1
When in doubt, clear a small test area on the ground, peel off a few wood curls, and try it with a lighter - you should only have to barely and I mean barely touch the curl - and it should ignite immediately- there will also be kind of a popping/sizzling noise - which indicates a lot of resin - the flame will also continue to move along the curl/shaving- popping as it goes - if it is really good fatwood, you can hold a larger curl and light the top of it, and the flame will travel downwards on the curl, almost like a candle.
Note - If it does not immediately ignite/have the light popping / sizzling sound - it's not the good stuff (based on my limited experience anyway)
Test 2
If it passes Test 1, try igniting some of the thin curls with your Firesteel - if you have a good throw of sparks - it should ignite very readily as well.
Last note - if you find an old pine that has exposed roots - don't give up if the outside of the roots feel a little punky from exposure to the weather.
Once you cut away the punky wood - unless it has been down for a long, long time - the pitch wood shoud be preserved underneath of it, as the Resin is an awesome preservative/sealant from the elements.
Remember - Fat wood is:
F - Found in in the roots/trunk of fallen Pines.
A - Available in any area where there are fallen Pines present.
T - Testable (is that a word?
) on the spot - no need to wonder if you have found the good stuff - just experiment.
When you do that - you can save your $ for one of those cool knives that Hollowdweller always posts just to drive us insane.
Be Well,
sp
(BTW - It is
Test 2
Be Well,
sp
